Re: Dana 60
[Re: jkwedge540]
#2487512
04/24/18 09:42 PM
04/24/18 09:42 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would think not. What's moving? Bearings not being retained and allowed to move? What kind of bearings?
Re: Dana 60
[Re: jkwedge540]
#2487667
04/25/18 08:54 AM
04/25/18 08:54 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I had the same problem. The outer retainer is wider than the bearing race. You can fabricate a spacer shim, but the right way is to install the snap ring style bearing to keep it located.
[image][/image]
Re: Dana 60
[Re: jkwedge540]
#2487925
04/25/18 07:31 PM
04/25/18 07:31 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
You have any pics of what I need . Thanks It's just a bearing with a groove for a snap-ring and a retainer flange separate from the bearing. It's not a one piece like the old "green" bearings. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
