130 + MPH BRAKES #2485048
04/19/18 12:23 PM
04/19/18 12:23 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
By the end of the summer, my W2 360 should be finished. At present, I'm running 10.50-60 with a SB in a 3000 lbs car. The new motor should be 10.10 to 9.90. Should I be thinking new brakes other than the stock factory 73 disc/drum combo?
Re: 130 + MPH BRAKES [Re: A/MP] #2485050
04/19/18 12:27 PM
04/19/18 12:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That combo will probably work just fine but you could shed some rotating mass with some aftermarket stuff. Personally I like the willwood stuff, it seems like a good value. I have had a front kit for about 15 years and am putting their discs on a D60 I am about to install.
68 Barracuda Formula S 340
Re: 130 + MPH BRAKES [Re: A/MP] #2485064
04/19/18 12:56 PM
04/19/18 12:56 PM
an8sec70cuda Offline
I have Aerospace brakes on my cuda and they work OK. Having said that, the next time I buy a brake kit it'll be Wilwood. Getting simple replacement parts from Aerospace can be a nightmare.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 130 + MPH BRAKES [Re: A/MP] #2485070
04/19/18 01:05 PM
04/19/18 01:05 PM
AndyF Online content
AndyF  Online Content
I'm putting a Doctor Diff Viper kit on the front of my Duster. I figure 130 mph will be a piece of cake with this setup.
Re: 130 + MPH BRAKES [Re: A/MP] #2485091
04/19/18 01:44 PM
04/19/18 01:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Whatever you do, plan the whole system instead of a bits and pieces approach. Master cylinder size, plumbing, get rid of OE valves and switches, and get the correct calipers and kits. Don't end up with dirt track parts and then wonder why the car won't stop.
Re: 130 + MPH BRAKES [Re: A/MP] #2485117
04/19/18 02:59 PM
04/19/18 02:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
Went from '73 disc front/ 10" drum rear to 4 wheel strange race brakes and the car stops MUCH better.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 130 + MPH BRAKES [Re: A/MP] #2485136
04/19/18 03:37 PM
04/19/18 03:37 PM
Which body style and size of the rear brakes does it have now?
The reason I'm asking is if you have the small OEM A body 10x1 3/4 rear drums just switching to a set of 10x2.5 brakes on the back will help your car stop a bunch better scope twocents
BTW, I use to run a 1970 A body car in S/ST that was a little heavier than yours with the original stock disc brakes and the stock size rear drums, I ended up having a brake relining CO in SO CA reline several sets of the shoes with fork lift linings, that made a big difference on the starting line foot braking as well as stopping in the 1/4 mile up
I might a set of those left, PM if your interested in a set thumbs
Re: 130 + MPH BRAKES [Re: A/MP] #2485220
04/19/18 07:04 PM
04/19/18 07:04 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I've got the 73 UCA and discs.
Re: 130 + MPH BRAKES [Re: A/MP] #2485253
04/19/18 08:33 PM
04/19/18 08:33 PM
Easy upgrade if you have 15 inch wheels is to install the larger 11.75 rotors. All you need is the larger rotors and the taller caliper bracket. You can do that swap in just a few minutes and you don't even need to bleed the brakes. The 11.75 rotors were used on the biggest B body cars so they should be fine for an A body at 130 mph.
If you want to take some weight off you can put Wilwood calipers on the larger 11.75 rotors. That is something I started doing about 20 years ago. DoctorDiff sells a kit for it now.
Re: 130 + MPH BRAKES [Re: an8sec70cuda] #2485314
04/19/18 10:41 PM
04/19/18 10:41 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just got through replacing my wilwood front rotors. I had some trouble but it was all my fault, first I forgot that I had vented rotors, then I ordered rotors from the current Abody kit and mine is 15 years old, third time was a charm though. Every one of my mistakes was in stock at Summit.
Re: 130 + MPH BRAKES [Re: A/MP] #2485322
04/19/18 11:02 PM
04/19/18 11:02 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
My old 63 Belvedere has been 9.23@145 on 4 wheel drum brakes, and before you say it dont worry I will never do it again.
1963 Plymouth Max Wedge
1971 Barracuda
Re: 130 + MPH BRAKES [Re: A/MP] #2485327
04/19/18 11:09 PM
04/19/18 11:09 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
As far as swept area goes, should be good. Use decent linings and fresh fluid. Nothing super fancy on the linings, but a decent friction rating.
Brake Lining Edge Codes (and temperatures)
Re: 130 + MPH BRAKES [Re: A/MP] #2485329
04/19/18 11:19 PM
04/19/18 11:19 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My Dart had Wilwoods on the front and stock drums in the back and went 9's at 136mph. It stopped fine.
Re: 130 + MPH BRAKES [Re: A/MP] #2485331
04/19/18 11:21 PM
04/19/18 11:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I do suggest vented rotors, especially if street driven.
I had 9" front drum spindles so the only kit I could find for that was the Strange-Engineering drag race kit with the thin non-vented rotors. It does ok but I would have been happier with something beefier like Wilwood.
Re: 130 + MPH BRAKES [Re: A/MP] #2485357
04/20/18 12:09 AM
04/20/18 12:09 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Depends on how much shut down area you have at the tracks you plan to race at. I went 9.30’s @ 145 in a 3300lb Duster with the same setup as you without issue.
Re: 130 + MPH BRAKES [Re: ozymaxwedge] #2485377
04/20/18 12:42 AM
04/20/18 12:42 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I'm giggling over this. I could imagine the look on your face when you got out of the car laugh2
Re: 130 + MPH BRAKES [Re: A/MP] #2486906
04/23/18 05:25 PM
04/23/18 05:25 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
go with the big 11.75" stock rotor. replace the caliper bracket get it from dr, diff
use some better pads.
easy and cheep
Re: 130 + MPH BRAKES [Re: A/MP] #2486974
04/23/18 09:20 PM
04/23/18 09:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
When the rears rims are bead lock,the ID of the rim is 13 inch.Caliper size matters for wheel clearance and back space need to be attended to.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 130 + MPH BRAKES [Re: A/MP] #2487033
04/23/18 11:27 PM
04/23/18 11:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I always find this conversation interesting. When we started running mid 9’s/ 140 I started KILLING my wilwood front rotors. At $150 a set, it was getting old. I recently added Strange rear discs to the mix and the car definitely stops easier. I’m still thinking of adding a proportion valve to the front to bias a little more to the rear.
Re: 130 + MPH BRAKES [Re: J_BODY] #2487069
04/24/18 12:27 AM
04/24/18 12:27 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have Wilwoods on all four corners of both my cars. We have one 1/8th mile track with a short shut down area...Nearly crashed the car at 110mph with stock disk brakes. Went with Wilwoods on all four corners, and its trapping 112mph now, and no problem, and no prop valve either....on either car. fantastic pedal feel too.
