Re: VICTOR MAX WEDGE HEADS! [Re: BradH] #2484865
04/18/18 10:51 PM
04/18/18 10:51 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By BradH
Originally Posted By Mal440
I would be interested in flow numbers you are getting? My head porter is working on a set for me currently when I read Hughes figures he didn't believe them. He doesn't believe there is 400 cfm in the head without going through in places. Doesn't like the rocker oil casting in the port, cross section is too small at the turn .Think he is at around 360 cfm at .700
Maybe these will give him some ideas:
http://speierracingheads.com/BBMv3.3.htm
https://www.buyracingparts.com/cnc-porte...roller-cam.html
Looking at those prices and claimed results make the Trick Flow offerings look better all the time.
Re: VICTOR MAX WEDGE HEADS! [Re: viperblue72] #2484989
04/19/18 10:16 AM
04/19/18 10:16 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I bought a pair of the Edelbrock MW heads from Todd at compititionwedge. They have been cnc'd by Hughes and measure 330cc intake port and 76cc chamber. I use Harland Sharp rockers push rod oiled. You can get there rockers either way, push rod oiled or shaft. I'm using the heads on a 511 with a solid flat tappet spec'd by Dwayne 270/276@50-.644/.615-110 using 1.6/1.5 rocker ratio. Heads flowed 356@650 on up. Pump gas deal with 11.25:1 compression.
Re: VICTOR MAX WEDGE HEADS! [Re: Mal440] #2485024
04/19/18 11:35 AM
04/19/18 11:35 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Button them up and call it good.
Re: VICTOR MAX WEDGE HEADS! [Re: fast68plymouth] #2485068
04/19/18 01:02 PM
04/19/18 01:02 PM
The Great White North
RAMM Offline
RAMM  Offline
Agree ^^^^^^^^^^^^^^^^^
Best I have ever done is 372 cfm @ .700" and that was one port that I was really developing. 400 cfm is going to be a very large port either way. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: VICTOR MAX WEDGE HEADS! [Re: fast68plymouth] #2485108
04/19/18 02:24 PM
04/19/18 02:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nooooohhhh!
Must
Make
More
Metal
Shavings!!! sawzall
Re: VICTOR MAX WEDGE HEADS! [Re: viperblue72] #2485259
04/19/18 08:39 PM
04/19/18 08:39 PM
Lynnwood WA
MikeStahl Offline
MikeStahl  Offline
Lynnwood WA
Here's What I got with port work from Jim Laroy and 2.25 valves
These are Procomps
CNC before in/ex............now in/ex
.100..........72/62................77/61
.200.........151/122.............156/140
.300.........218/171.............222/188
.400.........264/209.............280/223
.500.........296/240.............332/254
.600.........325/261.............354/276
.700.........342/271.............363/288
.800.........351/287.............370/304
Re: VICTOR MAX WEDGE HEADS! [Re: viperblue72] #2485450
04/20/18 05:13 AM
04/20/18 05:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had the Hughes CNC ported Victor MW heads flowed. and posted the flow sheet here:
https://board.moparts.org/ubbthreads/ubbt...tml#Post1946988
They flowed 377 @ 0.800" (360 @ 0.700") on a 4.310 bore fixture and no radius port entry. I think on a larger bore fixture and with a radius plate the numbers would show higher?
Best Machine also posted a flow sheet with 461.5 @ 0.700", but only 367.8 @ 0.800" That was on a 4.500" bore.
Re: VICTOR MAX WEDGE HEADS! [Re: 451Mopar] #2486020
04/21/18 11:56 AM
04/21/18 11:56 AM
BradH Offline
BradH  Offline
If there was no radiused entry used, the numbers aren't valid. Yet, those tests look fairly consistent with other tests I've seen.
Testing without a proper entry shape jacks up the results. Nobody I know who does this stuff ever tests without one.
