how do you test the
#2480684
04/10/18 07:49 PM
04/10/18 07:49 PM
Posts: 1,527 Michigan
GoDartGo
How do I test the control box? I got it new 7 years ago and never had any issues with it. It's the the orange control box and I'm not getting any spark. The coil is fairly new.
Re: how do you test the
[Re: GoDartGo]
#2480717
04/10/18 08:52 PM
04/10/18 08:52 PM
RapidRobert
You pretty much have to test/elim all but the box & I think O'reillys can test it. it has ran in the past with how you have it wired correct? 4 pin ECU/2 terminal ballast & it wont start so you subbed in the orange box to no avail? pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter & with your VOM see if the coil positive primary terminal & the main feed wire at the ECU are hot (it is the "point" of the pentastar), might be blue/yellow or red. ohm the dist pickup. check the reluctor gap (should be "close" but not touching) & the spec is .008" with a brass feeler gauge. confirm the box is grounded (it usually is but I would check). this'll get us started.
[Re: rory73]
#2480768
04/10/18 10:05 PM
04/10/18 10:05 PM
RapidRobert
^^^ Good info, thank you!
[Re: GoDartGo]
#2480916
04/11/18 03:47 AM
04/11/18 03:47 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Who here has even seen brass feeler gauges? Not I....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: GoDartGo]
#2480970
04/11/18 10:42 AM
04/11/18 10:42 AM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Who here has even seen brass feeler gauges? Not I.... I have a set!
[Re: Stanton]
#2480975
04/11/18 10:50 AM
04/11/18 10:50 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Who here has even seen brass feeler gauges? Not I.... I have a set! I have them too.
[Re: justinp61]
#2480983
04/11/18 11:06 AM
04/11/18 11:06 AM
Posts: 516 ND
dodgedon
ND
Every set I have has a few brass sizes in the mix.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#2481205
04/11/18 06:26 PM
04/11/18 06:26 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Every set I have has a few brass sizes in the mix. Same here. I have a set with several brass sizes int he mix.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
