74 Rallye Charger Wiring Harness Cleaning #2474961
03/31/18 05:47 PM
03/31/18 05:47 PM
Kennewick, Wa.
71vert340 Offline OP
Kennewick, Wa.
I've reinstalled the wiring harnesses in my 74 Charger. I checked all the wiring, the connections, etc. I'm ready to plug all the engine side plugs into the bulkhead connector box and all the steering column connections under the dash. What would you recommend cleaning and lubricating the plug connections with? What will not be affected by the engine heat in the engine compartment? Is electrical contact cleaner the best to use to remove grease and oil from the plugs or would the computer /electronics cleaner work best? I'm open for suggestions. Anyone use the dielectric grease? Thanks for any informational help with this in advance.
Terry
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: 71vert340] #2475081
03/31/18 09:44 PM
03/31/18 09:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Deoxit 5, you can find it on ebay.
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: 71vert340] #2475125
03/31/18 11:55 PM
03/31/18 11:55 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes,dielectric grease would work well to keep moisture out of a clean connection... Take precautions, the caustic chemicals/residue in any electronics cleaner wouldn't be good on the body components..
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: screamindriver] #2475348
04/01/18 01:30 PM
04/01/18 01:30 PM
Kennewick, Wa.
Kennewick, Wa.
Looking at the plugs, I don't see corrosion as much as I see little globs of old grease. Would rubbing alcohol work as a non-corrosive cleaner to get the grease out?
Terry
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: 71vert340] #2476746
04/03/18 01:29 PM
04/03/18 01:29 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i know not everybody has access to this but i have been experimenting with my vapor blaster (glass bead and water slurry in a cabinet) i have been having great luck on original plastics and rubber. a while back i thought i would try wiring. it does a great job. wiring is soft again and everything is nice and clean.
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: 71vert340] #2476768
04/03/18 02:21 PM
04/03/18 02:21 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I don't think blasting the metal terminals is a good idea, they will corrode much easier now. They do have a coating on the that protects them.
The exterior of,the plastic and wires looks good.
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: NANKET] #2476787
04/03/18 02:55 PM
04/03/18 02:55 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
you dont remove any coating with this blasting. Any green monster that was in it before blasting ate that coating a long time ago anyways
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: chrisf] #2476981
04/03/18 07:57 PM
04/03/18 07:57 PM
Kennewick, Wa.
Kennewick, Wa.
That looks great.
Terry
Re: 74 Rallye Charger Wiring Harness Cleaning [Re: 71vert340] #2477409
04/04/18 03:09 PM
04/04/18 03:09 PM
Chicago
PurpleBeeper Offline
Chicago
Terry
1. DeoxIT 5 works great to clean corrosion.
2. Dielectric grease works great to prevent future corrosion. Very old dielectric grease is the brown smudge you're looking at in the old connector.
3. Rubbing alcohol & a Q-tip would be a great "plastic safe" way to clean out the old, brown dielectric grease....then use some new dielectric grease & plug it in!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
