Lil Red Truck sheet metal
#2475553
04/01/18 08:05 PM
04/01/18 08:05 PM
Posts: 704 USA
rftroy
USA
I need floor pans for my Lil Red Truck. I have been searching and found this so far: http://www.lmctruck.com/icatalog/dc/full.aspx?Page=10and this: https://www.goodmarkindustries.com/c-2080-floor-pan-front-half-long.aspxThe LMC seems awfully cheap. I would suspect the quality. Goodmark is probably lackluster quality, but it is just a floor pan. Any other sources for Dodge truck cab sheet metal? Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Lil Red Truck sheet metal
[Re: rftroy]
#2475613
04/01/18 09:29 PM
04/01/18 09:29 PM
Posts: 5,815 ohio
ruderunner
ohio
Mill Supply. Occasionally rock auto.
Angry white pureblood male
[Re: ruderunner]
#2475630
04/01/18 10:09 PM
04/01/18 10:09 PM
Posts: 704 USA
rftroy
USA
Thanks. I’ll give it a shot. Bob
[Re: kenworth_goose]
#2475695
04/02/18 12:05 AM
04/02/18 12:05 AM
Posts: 704 USA
rftroy
USA
I may have floors from the 88 that I parted out. They were nice. Let me know. If they're in sections, the shipping might not be too bad. Bob
[Re: rftroy]
#2477762
04/05/18 09:35 AM
04/05/18 09:35 AM
Posts: 1,615 Table Rock Lake Missouri
furious
Here is where I ordered mine from last week. Should be here today. https://www.c2cfabrication.com/Wow, after looking at all the other links, I feel great about the prices on the ones I bought. Hopefully the quality is good. I would bet they are all coming off the same die though.
[Re: dirt]
#2477775
04/05/18 10:28 AM
04/05/18 10:28 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
90% of the Replacement Sheet metal that's out there is Pressed by the same cheap place, except Bit pricey but the are the best quality parts out there other than cutting a floor out of a rust free truck.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: furious]
#2478261
04/06/18 11:48 AM
04/06/18 11:48 AM
furious
Here is where I ordered mine from last week. Should be here today. https://www.c2cfabrication.com/Wow, after looking at all the other links, I feel great about the prices on the ones I bought. Hopefully the quality is good. I would bet they are all coming off the same die though. Floor pans and cab supports came in yesterday and I am impressed. Packed well and floor pans are made of pretty heavy material. Label says made in Taiwan. Will see how the fit goes. We will see on the cab supports, they look pretty crude.
[Re: rftroy]
#2478662
04/07/18 02:40 AM
04/07/18 02:40 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
If you don't like them, I have a set from autobody specialties I won't be using...doing a cab swap.
1981 Dodge D150 360 auto
[Re: basketcase]
#2479069
04/07/18 09:44 PM
04/07/18 09:44 PM
furious
If you don't like them, I have a set from autobody specialties I won't be using...doing a cab swap. Not intending to highjack the OP thread, but I believe you are talking to me right basketcase? So far I really like the floor pans and anymore shipping is a pretty big expense out here in the boondocks. They are made to fit both the 2wd and 4wd larger hump floors, you just have to cut the area away you don't need for the large hump. Also, the hole for the cab mount bolts is not cut out, but it is formed, but that is no biggie to me. Now that I have the old butcher job removed I have learned I am going to be needing the rear cab floor metal though and the patch panels for over the wheels on the bed if you have those available?
[Re: rftroy]
#2479214
04/08/18 02:20 AM
04/08/18 02:20 AM
basketcase
east side of Ohio
yes I was furious. and to be clear, I meant the front cab mounts. was going to fix my cab, but it's too far gone.
