Re: R3 build advice
[Re: mopartyson]
#2475120
03/31/18 11:42 PM
03/31/18 11:42 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
When you say 49 degree, is this an altered 48 degree block? 48 degree block is a much better starting point for a performance build. No lifter clearance problems or port intrusion from pushrod pinch. Cam cores can be hard to find depending on journal size. Intake lifter location is spread wider for pushrod angle correction over the 59 degree blocks. Some of these low deck r3 48 degree blocks are dry sump oiling only, so I hope you are prepared for that. Also be prepared to part with some cash with rocker assys for this deal. Also if i recall correctly, the waterpump/ timing cover is different on the low deck height blocks.
Re: R3 build advice
[Re: TRENDZ]
#2475122
03/31/18 11:50 PM
03/31/18 11:50 PM
Posts: 36 Arkansas
mopartyson
Arkansas
Yes I meant 48 degree. I'm on my phone lol. It is dry sump which I'm told is not hard or exspensive to machine for wet sump. The cam bearings are 60mm. Like I said I'm out of my league here and wondering if the good deal on the block is worth it. $1500 for the block
Re: R3 build advice
[Re: mopartyson]
#2475123
03/31/18 11:51 PM
03/31/18 11:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this a wet or dry sump block would bore it to 4.185 and a then decide what stroke you want.. that bore is chevy.. are you gonna go injection or not
Re: R3 build advice
[Re: mopartyson]
#2475134
04/01/18 12:19 AM
04/01/18 12:19 AM
MR_P_BODY
Yes it dry sump. Does anyone know about converting it to wet sump. Dry sump absolutely will not work for me. It will have to be carbed My R3 was a dry sump and I built it that way.. W-9 heads
Re: R3 build advice
[Re: mopartyson]
#2475142
04/01/18 12:42 AM
04/01/18 12:42 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
If you are just doing the build for mud bogging fun lke your saying...... what you are embarking on is a very expensive journey. Just in heads and rocker gear you will have well North of 5 grand, everything else is expensive too.
Doubt i would go down that path just for kicks. Could build a 360/408 combo with heads and all for what you would have just in the top end of this thing.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: R3 build advice
[Re: mopartyson]
#2475145
04/01/18 12:45 AM
04/01/18 12:45 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a used 48 degree block and assembly that I haven’t touched yet. I have a 59 degree R3 in my black Duster. I posted some pictures of it while I was building it and another Moparts member suggested putting more oil drain back oil holes In The intake valley. Th previous owner drilled some but I drilled several bigger holes. I also bought an accumulator but it wasn’t needed
Re: R3 build advice
[Re: mopartyson]
#2475149
04/01/18 12:53 AM
04/01/18 12:53 AM
MR_P_BODY
Dry sump and mud just ain't gonna mix I assume there is a way to take a dry sump block and turn it into a wet sump.. I never did it
Re: R3 build advice
[Re: B3422W5]
#2475171
04/01/18 01:57 AM
04/01/18 01:57 AM
Posts: 36 Arkansas
mopartyson
Arkansas
Doubt i would go down that path just for kicks. Could build a 360/408 combo with heads and all for what you would have just in the top end of this thing. Some of these guys are running engines upwards of 25,000. It's get pretty serious, it's not just throwing a lil mud around. We go out of state to races. If you want to see what I'm talking about check out AMRA mud racing page on facebook. Or search horseshoe mud racing on youtube.
Re: R3 build advice
[Re: MR_P_BODY]
#2475173
04/01/18 01:59 AM
04/01/18 01:59 AM
Posts: 36 Arkansas
mopartyson
Arkansas
Dry sump and mud just ain't gonna mix I assume there is a way to take a dry sump block and turn it into a wet sump.. I never did it I was reading something on it earlier but damned if I can find it now
Re: R3 build advice
[Re: mopartyson]
#2475174
04/01/18 02:03 AM
04/01/18 02:03 AM
Posts: 36 Arkansas
mopartyson
Arkansas
The class I would be in would be 800-1000hp trucks running a 1/4 mile long horseshoe shaped mud track. I know I'm not going to best route to win. I just want to build a stout small block dodge and put some dents in some chevys. This is a rough sport and the truck body and chassis gets replaced every couple years.
Re: R3 build advice
[Re: mopartyson]
#2475224
04/01/18 11:10 AM
04/01/18 11:10 AM
TRENDZ
Milwaukee WI
Not speaking for the OP, but I think the dry sump problem would be the fact that it is belt driven. I can see why in mud you wouldn’t want a belt driven pump. I do like your work around! Sort of a hybrid dry/wet system
