Re: R3 build advice [Re: mopartyson] #2475235
04/01/18 11:32 AM
04/01/18 11:32 AM
Arkansas
mopartyson Offline OP
Arkansas
I'll give him a call. Yea the belt drive is the concern, motor compartment would be sealed as tight as possible but some will still get through. I'm thinking a 4.180 crank and 4.185 bore. Being a 4x I need some torque. This engine will probably end up in my 87 D150 after I race it some.
Re: R3 build advice [Re: mopartyson] #2475237
04/01/18 11:34 AM
04/01/18 11:34 AM
Arkansas
Arkansas
Or does anyone still offer the 4.25 stroke crankshaft?
Re: R3 build advice [Re: mopartyson] #2475341
04/01/18 01:23 PM
04/01/18 01:23 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
You dont need a belt drive you can use a 9 inch timing cover and you will have a hard time getting any thing bigger then a 4 inch crank in a 9 inch deck block
Re: R3 build advice [Re: mopartyson] #2475381
04/01/18 02:25 PM
04/01/18 02:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Member here BPE sell them. Have one in my R3 W9 deal.
This is my opinion so take it as you want.
Build an G3 Not an R3. The stock heads are more than enough to support what YOUR looking for now and the blocks are as tough as the R3 and you can get them anywhere. CNC the heads down the road and NO Victor small block head will touch it.
The thing with the G3 is that there is TONS of parts. Break something and Your not hunting for Hens teeth.
Once again Just my opinion.
If your going with the R3 and using indy heads or W2 I have new in the box TD rockers shaft mounted 1.65 ratio.
Matt
Re: R3 build advice [Re: scottb] #2475384
04/01/18 02:32 PM
04/01/18 02:32 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would think a good starting point would be get the block completely measured up figure out what the true deck height is. Don't rush into anything.. sort out your exact path. I think if you could build an enclosure for a single stage external pump.. you would be better off. I know if I was going to keep an engine at an extremely high RPM for a long period Of time I would definitely want an external pump.. good luck and keep us posted on your progress..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: R3 build advice [Re: MattW] #2475393
04/01/18 02:49 PM
04/01/18 02:49 PM
Arkansas
Arkansas
Matt
Cant run a hemi. As with every racing association the rules are extremely chevy biased.
Re: R3 build advice [Re: scottb] #2475394
04/01/18 02:51 PM
04/01/18 02:51 PM
Arkansas
Arkansas
Please explain
Re: R3 build advice [Re: mopartyson] #2475412
04/01/18 03:31 PM
04/01/18 03:31 PM
HR3128 Offline
HR3128  Offline
Please explain
I think there was a little mix-up between belt drive oil pump & belt drive timing gear.
There are low deck blocks use a special front cover. These front covers do not accept a stock type water pump, only electric pumps.
There are also belt drive cam gear set-ups. Big bucks.
Re: R3 build advice [Re: HR3128] #2475423
04/01/18 03:47 PM
04/01/18 03:47 PM
Arkansas
Arkansas
Yes I'm having a hard time finding out which this is since it is discontinued.
Re: R3 build advice [Re: mopartyson] #2475426
04/01/18 03:52 PM
04/01/18 03:52 PM
Arkansas
Arkansas
I'm going to build something else. If someone wants this block I can put you in contact with the seller. If it fits someone's desires I think $1500 for a new block is cheap
Re: R3 build advice [Re: mopartyson] #2475445
04/01/18 04:19 PM
04/01/18 04:19 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call Shadydell and talk to Ryan he can explain everything to you or Brett Miller just dont give up there are some very smart guys out there making big power with these engines its like building a new house you need a good foundation so start with a race block ck out ryans web page some good info over there shadydell.com
Re: R3 build advice [Re: scottb] #2475853
04/02/18 06:06 AM
04/02/18 06:06 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
Ryan is doing machine work on my 9.20 deck r3 now. I was told by him that any stroke bigger then 3.79 will need the counterweight of the crank turned down in a short deck block.
Re: R3 build advice [Re: mopartyson] #2476523
04/02/18 11:07 PM
04/02/18 11:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My 4” Molnar fit my 9.20 block....
Re: R3 build advice [Re: mopartyson] #2476544
04/02/18 11:54 PM
04/02/18 11:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I ran a 4.00 Callie’s in a 9.3 deck and had plenty of room
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: R3 build advice [Re: mopartyson] #2476562
04/03/18 12:23 AM
04/03/18 12:23 AM
Arkansas
Arkansas
I think I'm going to drop down a class and cheat. How about a 426 in a production block with a solid roller and a set of W2 heads? The class rules are factory heads and a hydraulic flat tappet. But if I'm gonna run against big blocks I don't stand a chance running those. Most everyone is cheating so I don't feel bad about it. I don't think anyone will notice the w2 heads because no one runs a small block mopar. Trick is gonna be getting it to pull 14" vacuum at 1000 rpm
