A body brake suggestion
#2472117
03/26/18 02:13 AM
03/26/18 02:13 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Need to get into a better braking system The cars a 71 demon Has factory sbp front disk brakes Rear is LBP drums using aftermarket axles
Like the looks of the willwood calipers obviously
Currently leaning towards a 17x7 front wheel and a 17x9.5 or wider rear wheel What kits are available that I can inquire about Most stuff I see is based of drum spindles
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: A body brake suggestion
[Re: BigBlockMopar]
#2472514
03/26/18 09:58 PM
03/26/18 09:58 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
Does anyone (still?) sell a 'simple' and affordable Wilwood caliper on a stock 11.75" disc system?
Of course the Wilwood claiper would need to have a minimal 2.75" piston area just like the stock calipers had.
I think to recall having seen Andy made brackets for this purpose but he stopped producing them because of low demand? Or was this something else he made once?
Those were brackets that adapted gen 1 Viper brakes to the 11.75 rotors. I remember seeing them in Mopar Action. Wish he still made them.
[Re: gremlinsteve]
#2472545
03/26/18 11:21 PM
03/26/18 11:21 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I put the Mustang Cobra brakes from Dr Diff on my Duster...13" front, 11.75" rear. Great brakes, especially with the hydroboost, which pushes them over the edge to insane. 73 Disk spindles and 68 B-body 8 3/4
The car has 18x9 +35 at all 4 corners and 275-35-18 tires.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: BigBlockMopar]
#2472570
03/27/18 12:30 AM
03/27/18 12:30 AM
Posts: 31,041 Oregon
AndyF
I sold the design for the Wilwood on 11.75 rotor to DoctorDiff when I got out of the brake business.
[Re: gremlinsteve]
#2472571
03/27/18 12:33 AM
03/27/18 12:33 AM
AndyF
Currently leaning towards a 17x7 front wheel and a 17x9.5 or wider rear wheel What kits are available that I can inquire about Most stuff I see is based of drum spindles I'm putting Viper calipers with 13 inch rotors on the front of my '72 Duster. I'll be using a 17x6 wheel with a 205/55-17 tire since it is more of a drag race car than a corner burner.
