100 amp alternator brackets
#2471422
03/24/18 05:50 PM
03/24/18 05:50 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Has anybody swapped to smaller brackets on a car with a 100 amp alternator? Can I run older brackets from a 60 amp alternator with the bigger altenator if I change the brackets and pulleys???
CrAzYMoPaRGuY
Re: 100 amp alternator brackets
[Re: CrAzYMoPaRGuY]
#2471462
03/24/18 07:03 PM
03/24/18 07:03 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Tough Stuff sells a bolt on direct Mopar replacement 100 amp alternator that is black powder coated that works very well, even without replacing any wires ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Mount and plug it in and go ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I used one for many years on my old pump gas Duster, I will use them again on another street car
[Re: CrAzYMoPaRGuY]
#2471700
03/25/18 10:56 AM
03/25/18 10:56 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
back in the days, the 100 amps alt was called Leece neville alts which uses a quite diff alternator bracket setup. Is not really about the output but the diff manufacturer alternator( pic posted )
At this moment you can get 100 and up to 130 amps alt from tuff stuff, and several other manufacturers on the same casing of the regular alts so keeping the existant brackets. These newer alts should be on around 60 amps rate at iddle which should be quite enough. Sooooo I wouldn't take care about the brackets for 100 amps Leece neville alts unless you reall want those for whatever reason.
you can get even a 78 amps stock alts from earlier to mids 80s which will fit nice too and works, on stock replacemenet price rate. they are A BIT wider, maybe couple of mm, so fits a bit tighter. Is the one I'm running ( driver with AC ) and I trimmed a bit the rear spacer and got a bit longer belts to sway the rear of alt from block.
[Re: NachoRT74]
#2471702
03/25/18 11:04 AM
03/25/18 11:04 AM
RapidRobert
I hear the Leece Neville units work well but are real heavy (alt+bracketry). I have one but its still on the shelf.
[Re: NachoRT74]
#2471825
03/25/18 03:08 PM
03/25/18 03:08 PM
CrAzYMoPaRGuY
Canada
That's the setup I want to remove. Big, bulky, not too attractive. Like my ex.... I had a new PowerMaster 100 amp on my Jensen, it only lasted a few months before it stopped charging, so I guess I just worry the newer stuff looks great on paper but it ain't high in the quality department...... Is Tuff Stuff a good name as far as quality goes? Thanks!!!!!!!!!!!!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2471855
03/25/18 04:13 PM
03/25/18 04:13 PM
NachoRT74
Valencia, España
as far I know they are good quality. I have known one got failed from a member on DC.com, but was replaced without questions, and got it working.
Just would need to get the regular brackets I guess. If AC car, they get an extra attaching point on engine mount provision on block ( if BB ). And upper bracket is a bit diff and smaller from non AC cars
[Re: CrAzYMoPaRGuY]
#2471893
03/25/18 05:10 PM
03/25/18 05:10 PM
NachoRT74
Valencia, España
this would be the A/C setup... where I guess the upper OR the rear provision to head is diff between RB and B same as the non A/C got the upper front ebay link bracket setup AC
[Re: NachoRT74]
#2471930
03/25/18 06:28 PM
03/25/18 06:28 PM
RapidRobert
With an aftermarket alt I had heard way back that keeping the OE style 3 wire type was better than a 1 wire alt. Any thoughts?
[Re: RapidRobert]
#2471936
03/25/18 06:42 PM
03/25/18 06:42 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
With an aftermarket alt I had heard way back that keeping the OE style 3 wire type was better than a 1 wire alt. Any thoughts? From my research, in a stock daily driver type situation I think that's right. This late '80's mopar truck nip alternator is my best choice maintaining stock brackets, I think? Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: NachoRT74]
#2471945
03/25/18 07:11 PM
03/25/18 07:11 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
back in the days, the 100 amps alt was called Leece neville alts which uses a quite diff alternator bracket setup. And a different regulator.
[Re: 3hundred]
#2471946
03/25/18 07:13 PM
03/25/18 07:13 PM
RapidRobert
^^ is that the 78 amper with the thin stator
[Re: RapidRobert]
#2471952
03/25/18 08:02 PM
03/25/18 08:02 PM
3hundred
Colleyville
Says it's 120A with overall dimensions 8x8x8.
Robert
[Re: John_Kunkel]
#2472052
03/25/18 11:27 PM
03/25/18 11:27 PM
NachoRT74
Valencia, España
back in the days, the 100 amps alt was called Leece neville alts which uses a quite diff alternator bracket setup. And a different regulator. yes I heard that but never have seen which one ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
