100 amp alternator brackets #2471422
03/24/18 05:50 PM
03/24/18 05:50 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
Has anybody swapped to smaller brackets on a car with a 100 amp alternator? Can I run older brackets from a 60 amp alternator with the bigger altenator if I change the brackets and pulleys???
CrAzYMoPaRGuY
Re: 100 amp alternator brackets [Re: CrAzYMoPaRGuY] #2471462
03/24/18 07:03 PM
03/24/18 07:03 PM
Tough Stuff sells a bolt on direct Mopar replacement 100 amp alternator that is black powder coated that works very well, even without replacing any wires up
Mount and plug it in and go wrench up
I used one for many years on my old pump gas Duster, I will use them again on another street car thumbs
Re: 100 amp alternator brackets [Re: Cab_Burge] #2471563
03/24/18 10:04 PM
03/24/18 10:04 PM
IN
ahy Offline
ahy  Offline
IN
The big frame 100A alternator uses its own brackets. It is physically bigger, heavier and belt adjustment travels in a bigger arc vs the standard roundback/squareback. I have both setups for a BB and alternators will not interchange.
There are plenty of high output squarebacks out there as mentioned... still idle output on these is a bit weak. The big case 100A has great idle output which is why I run it... even though it is heavy.
Re: 100 amp alternator brackets [Re: CrAzYMoPaRGuY] #2471569
03/24/18 10:24 PM
03/24/18 10:24 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yes you can change all of the brackets from the large dinner plate style alternator to the more common smaller alternator. I don't know for sure about the pulleys. I think I have every possible combination of pulleys that don't work. When I ditched the 100 amp on my 400 i just bought new brackets and pulleys.
Re: 100 amp alternator brackets [Re: CrAzYMoPaRGuY] #2471700
03/25/18 10:56 AM
03/25/18 10:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
back in the days, the 100 amps alt was called Leece neville alts which uses a quite diff alternator bracket setup. Is not really about the output but the diff manufacturer alternator( pic posted )
At this moment you can get 100 and up to 130 amps alt from tuff stuff, and several other manufacturers on the same casing of the regular alts so keeping the existant brackets. These newer alts should be on around 60 amps rate at iddle which should be quite enough. Sooooo I wouldn't take care about the brackets for 100 amps Leece neville alts unless you reall want those for whatever reason.
you can get even a 78 amps stock alts from earlier to mids 80s which will fit nice too and works, on stock replacemenet price rate. they are A BIT wider, maybe couple of mm, so fits a bit tighter. Is the one I'm running ( driver with AC ) and I trimmed a bit the rear spacer and got a bit longer belts to sway the rear of alt from block.
Re: 100 amp alternator brackets [Re: NachoRT74] #2471702
03/25/18 11:04 AM
03/25/18 11:04 AM
I hear the Leece Neville units work well but are real heavy (alt+bracketry). I have one but its still on the shelf.
Re: 100 amp alternator brackets [Re: RapidRobert] #2471736
03/25/18 12:20 PM
03/25/18 12:20 PM
moparx Offline
moparx  Offline
you ain't a kidding on the weight of those alternators ! but they ARE very rugged and dependable/reliable units for sure.
beer
Re: 100 amp alternator brackets [Re: NachoRT74] #2471825
03/25/18 03:08 PM
03/25/18 03:08 PM
Canada
Canada
That's the setup I want to remove. Big, bulky, not too attractive. Like my ex....
I had a new PowerMaster 100 amp on my Jensen, it only lasted a few months before it stopped charging, so I guess I just worry the newer stuff looks great on paper but it ain't high in the quality department......
Is Tuff Stuff a good name as far as quality goes?
Thanks!!!!!!!!!!!!
CrAzYMoPaRGuY
Re: 100 amp alternator brackets [Re: CrAzYMoPaRGuY] #2471855
03/25/18 04:13 PM
03/25/18 04:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I know they are good quality. I have known one got failed from a member on DC.com, but was replaced without questions, and got it working.
Just would need to get the regular brackets I guess. If AC car, they get an extra attaching point on engine mount provision on block ( if BB ). And upper bracket is a bit diff and smaller from non AC cars
Re: 100 amp alternator brackets [Re: CrAzYMoPaRGuY] #2471893
03/25/18 05:10 PM
03/25/18 05:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
this would be the A/C setup... where I guess the upper OR the rear provision to head is diff between RB and B same as the non A/C got the upper front
ebay link bracket setup AC
Re: 100 amp alternator brackets [Re: NachoRT74] #2471930
03/25/18 06:28 PM
03/25/18 06:28 PM
With an aftermarket alt I had heard way back that keeping the OE style 3 wire type was better than a 1 wire alt. Any thoughts?
Re: 100 amp alternator brackets [Re: RapidRobert] #2471936
03/25/18 06:42 PM
03/25/18 06:42 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
From my research, in a stock daily driver type situation I think that's right. This late '80's mopar truck nip alternator is my best choice maintaining stock brackets, I think?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 100 amp alternator brackets [Re: NachoRT74] #2471945
03/25/18 07:11 PM
03/25/18 07:11 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
And a different regulator.
Re: 100 amp alternator brackets [Re: 3hundred] #2471946
03/25/18 07:13 PM
03/25/18 07:13 PM
^^ is that the 78 amper with the thin stator
Re: 100 amp alternator brackets [Re: RapidRobert] #2471952
03/25/18 08:02 PM
03/25/18 08:02 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Says it's 120A with overall dimensions 8x8x8.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 100 amp alternator brackets [Re: John_Kunkel] #2472052
03/25/18 11:27 PM
03/25/18 11:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes I heard that but never have seen which one shruggy
