indy mod man intake #2471271
03/24/18 11:10 AM
03/24/18 11:10 AM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
are they still avail? are they max wedge port? what is the opinion of them? thanks in advance
Re: indy mod man intake [Re: rbkt65] #2471280
03/24/18 11:51 AM
03/24/18 11:51 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Can't answer your question, but has anyone done a cylinder-to-cylinder test for mixture distribution?
I can't see how the end runners (1, 2, 7, 8) are anywhere near the center runners (3, 4, 5, 6). That giant shoe-box plenum has all the fuel drop-out of a tunnel ram, without the mixture velocity in the runners.
Boffin Emeritus
Re: indy mod man intake [Re: rbkt65] #2471295
03/24/18 12:20 PM
03/24/18 12:20 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
yes from INDY - or your favorite INDY dealer - they come either way standard port of max-wedge - do they work - depends on what you are doing. I have one on my 65 coronet with ez-1 heads - it works better than the factory cross ram did. I run two 600 AFB's on it. a couple of guys are running them in NSS and having luck with them. It is not the best designed intake but the fuel distribution is really not that awful with dual quads.
Re: indy mod man intake [Re: rbkt65] #2471307
03/24/18 12:35 PM
03/24/18 12:35 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
i sure hope it works. I'm gonna find out here real soon. brand new car and engine. if not i guess i will put the ka-boom! intake back on and take my chances.
Re: indy mod man intake [Re: 64hemi330sedan] #2471394
03/24/18 04:24 PM
03/24/18 04:24 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Let us know how it works, I may get one if it does ok. Thanks
Re: indy mod man intake [Re: rbkt65] #2471443
03/24/18 06:41 PM
03/24/18 06:41 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
They are stock port but you can open open up to max wedge, havent looked at in a couple years .
Was too big a plenum for my 440 , even with a approximate 20% reduction of volume using a insert . Did seem to have poor carb signal , had to push a lot of jet in it
Drove good on street and made same hp as HP1000 holley on m1 and 1" open spacer . Just soft sixty at track footbraking . Did try 1 and 2" 4 poft spacers but saw no real gain
Am aiming to set up on my 505 in the next 2 weeks . Should be better plus i am leaving higher off a transbrake
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: indy mod man intake [Re: 64hemi330sedan] #2471454
03/24/18 06:52 PM
03/24/18 06:52 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Looks great !!
Re: indy mod man intake [Re: rbkt65] #2471456
03/24/18 06:56 PM
03/24/18 06:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
about as technological as a crow bar.
Re: indy mod man intake [Re: lewtot184] #2471522
03/24/18 08:50 PM
03/24/18 08:50 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
And yet it is still more effective than most of the readily available alternatives for a Nss legal intake.
Re: indy mod man intake [Re: GomangoCuda] #2471535
03/24/18 09:18 PM
03/24/18 09:18 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
... and fits under most stock hoods
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: indy mod man intake [Re: rbkt65] #2471554
03/24/18 09:56 PM
03/24/18 09:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Mod Man works, but not at the same power level. When the "Kaboom" is correct it doesn't Kaboom. Proper starting procedure and 500 passes proves this out. Well over 2000 starts (since proper starting procedure) w/o a Kaboom.
Doug
Re: indy mod man intake [Re: rbkt65] #2471567
03/24/18 10:17 PM
03/24/18 10:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Based on the pictures I've seen, it looks like the end ports are longer, farther away from the closest venturi.
Assuming all 8 bbls. match (throttle + venturi), has anyone tried +1 jets in the end bbls. (front primaries, rear secondaries)?
Boffin Emeritus
Re: indy mod man intake [Re: rbkt65] #2471614
03/25/18 12:40 AM
03/25/18 12:40 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
PS , when i asked Indy way back they said i needed more RPM to get the best out if it . I was shifting at 6000 trap 6300
I still only shift at 6000 but trap at 6700 . Leaving at 3500 instead of 2300
Tex
New best MPH 130.32
Re: indy mod man intake [Re: rbkt65] #2472247
03/26/18 12:18 PM
03/26/18 12:18 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I have run a modman since 2013 I think.
It works.
It will work as a bolt on. Spending time and figuring out what it wants will certainly help. I ran mine out of the box up until last year. We are index racing and I needed to slow down so I didn't care to re invent the wheel.
Last year I decided to try a few things and see what it had in it.
My observations.
1. It absolutely likes rpm. When short shifting it will work its way down track and when it gets up above 6600 it will start pulling.
2. It needs more jet than you think it does. Possibly due to less than optimal fuel distribution in the plenum.
3. You will read people talking about plenum fillers or stuffers. Do not bother. Dont decrease the flow, REDIRECT the flow.
Its a good piece and it fits under most hoods.
I am now working on a best possible combination for my car. A pair of edelbrock 750s make great mph and et. They do not react as well as my 600s did.
I have not tried staggered jetting as mentioned earlier in the thread.
Re: indy mod man intake [Re: dvw] #2472281
03/26/18 01:45 PM
03/26/18 01:45 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Hey Doug,
Can you share the proper starting procedure or is this proprietary?
Re: indy mod man intake [Re: rbkt65] #2472315
03/26/18 02:49 PM
03/26/18 02:49 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I can tell you how I do mine.
cold:
cycle the pump on and off 3 times.
give it 3 pumps of the throttle.
let it sit for a few seconds.
Crack the throttle.
spin the motor and then throw the fire to it
Warm:
pat the throttle once.
Crack the throttle.
Re: indy mod man intake [Re: 66coronet] #2472323
03/26/18 03:13 PM
03/26/18 03:13 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
On the 440-25 intake just put two of the wilson nitrous pop-off valves on it - and dont worry about it going KaBoom - They work very well!
Re: indy mod man intake [Re: DoubleD] #2472390
03/26/18 05:39 PM
03/26/18 05:39 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the Wilsom Pop offs on my Indy tunnel ram also. Hard to see with everything else going on but they are there.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: indy mod man intake [Re: lewtot184] #2472406
03/26/18 06:02 PM
03/26/18 06:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box.
I hope people make them work, 'cuz I'm happy I don't have to.
Re: indy mod man intake [Re: 66coronet] #2472446
03/26/18 07:14 PM
03/26/18 07:14 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
It works.
My observations.
what cubic inches motor size ?
couple pics of my insert , hope it also directs air flow out towards ports
Tex
New best MPH 130.32
