Looking for off the self app for Fanclutch. 69 Bbody #246123
03/07/09 07:57 PM
03/07/09 07:57 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
I have 3 fan clutches and none fit in my coronet. Its a 383 with the stock 053 rad.
I only have 3 3/8 clearance between the W/P and the rad.
All my clutches are a total of 3 3/8". The shafts are 1" and the distance between the mounting surface and the back of the clutch is 1.25".
Does anyone know of a application or p/N of a aftermarket clutch that has a shorter shaft or more clearance?
The mopar fan package is big money compared to the parts store clutches.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Looking for off the self app for Fanclutch. 69 Bbody [Re: CrAlt] #246124
03/07/09 08:35 PM
03/07/09 08:35 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Here is a little diag of my problem...
"A" is 1". I need it to be like 1/2"
Or take 1/2"+ off of "B" which is 3 3/8 on the clutchs i have.
Re: Looking for off the self app for Fanclutch. 69 Bbody [Re: CrAlt] #246125
03/08/09 02:42 PM
03/08/09 02:42 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The clutch fan for the Jaguar is 2.67" tall. Hayden part number 2765. It will fit a Mopar, but make sure the pilot shaft bushing is with the clutch.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Looking for off the self app for Fanclutch. 69 Bbody [Re: Junky] #246126
03/08/09 02:54 PM
03/08/09 02:54 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Thats what I am running in my Superbee and Power Wagon. And for sure check for the pilot bushing. I got one from Advanced and it was missing.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: Looking for off the self app for Fanclutch. 69 Bbody [Re: 69superbee383] #246127
03/08/09 04:03 PM
03/08/09 04:03 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
The stock replacement is a little longer I think they were made just for the 2 core radiator applications. I used the Hayden 2765 too.
Here it is in the car with a 4 core stock radiator and your stock fan.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
