Re: Best way to attach windage tray inside oil pan'm sic
[Re: 590 Challenger]
#2460201
03/02/18 10:27 PM
03/02/18 10:27 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I use a full length Milodon pan that has the windage tray held in on Dzus fasteners. I have a crankscraper siliconed to the bottom of the block. That usually stays in place, but if you have to pull one, you usually have to pull the other. I'm sure you could change out some main cap hardware and attach a windage tray to the main studs like a small block.
[image][/image]
[Re: sgcuda]
#2460278
03/03/18 01:11 AM
03/03/18 01:11 AM
Posts: 493 Parts unknown
590 Challenger
Parts unknown
I use a full length Milodon pan that has the windage tray held in on Dzus fasteners. I have a crankscraper siliconed to the bottom of the block. That usually stays in place, but if you have to pull one, you usually have to pull the other. I'm sure you could change out some main cap hardware and attach a windage tray to the main studs like a small block. I like that idea, I have threaded holes in the mains so I can pull them
#2460708
03/04/18 01:52 AM
03/04/18 01:52 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I use a crank scraper sandwiched with an aluminum pan.Superperformance gaskets and it's dry as a bone.
[Re: dvw]
#2460782
03/04/18 11:14 AM
03/04/18 11:14 AM
Posts: 2,933 A shed in England
Tig
A shed in England
I run no upper windage tray or crank scraper. Charlies pan with a screen bolted in. 7100 every pass, no issues with oiling Doug I think the screen will have some effect, almost like a windage tray. IMHO I wouldn't run without one, at least with with any sort of stroked motor. We have a 5.0 stroke 655 that basically runs the same pan and oiling system as our 572 (4.5 x 4.5). The pan is custom, long length but shallow for ground clearance. We couldn't swap over the windage tray that we use in the 572 for obvious reasons so we ran without it in the 655. We used to lose oil pressure in the shutdown, it didn't drop to zero but it used to get low (down to 15psi). At idle, hot it's around 45psi. This never happened with the 572. We also run an accumulator. Bearings looked fine on strip down, we didn't do that many runs that season anyway but we are getting a custom tray/scraper built. I see it as cheap insurance on wet sump systems.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
#2460826
03/04/18 12:28 PM
03/04/18 12:28 PM
sgcuda
Windage trays and crank scrapers need to be as close as possible to the crankshaft. Locating them deeper into the oil pan negates their purpose. Putting O rings between the block and tray or scraper will make it easier to remove the pan and tray as a single unit. If your scraper is a close fit, using dowel pins for proper location is highly recommended.
[image][/image]
