Best way to attach windage tray inside oil pan'm sic #2459897
03/02/18 01:37 PM
03/02/18 01:37 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
I'm tired of sandwiching the windage tray and using double gaskets and tons of RTV to seal my oil pan. MY buddy is going to machine a half inch aluminum plate, drill holes in it and put in O ring grove. I will cut the top of my pan off and weld this on. I hear some people install the windage tray inside the oil pan so it doesn't get sandwiched in there. What is the best way to attach it? I'm a little worried about losing hardware inside the pan. Pics would be great, thanks
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460201
03/02/18 10:27 PM
03/02/18 10:27 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I use a full length Milodon pan that has the windage tray held in on Dzus fasteners. I have a crankscraper siliconed to the bottom of the block. That usually stays in place, but if you have to pull one, you usually have to pull the other.
I'm sure you could change out some main cap hardware and attach a windage tray to the main studs like a small block.
[image][/image]
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460265
03/03/18 12:41 AM
03/03/18 12:41 AM
Why not follow the crowd and attach it inside the oil pan with Dzuz fasteners like most of the better drag race oil pan makers do shruggy
Re: Best way to attach windage tray inside oil pan'm sic [Re: sgcuda] #2460278
03/03/18 01:11 AM
03/03/18 01:11 AM
Parts unknown
Parts unknown
I like that idea, I have threaded holes in the mains so I can pull them
Re: Best way to attach windage tray inside oil pan'm sic [Re: Cab_Burge] #2460279
03/03/18 01:13 AM
03/03/18 01:13 AM
Parts unknown
Parts unknown
I'm asking because I have never seen it done before. I have only ever used the sandwich style. I was hoping for a pic, to copy how it was done
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460285
03/03/18 01:22 AM
03/03/18 01:22 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd check Milidon site. That's who's I have. Its on the car or I'd show you.
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460297
03/03/18 01:39 AM
03/03/18 01:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460304
03/03/18 02:03 AM
03/03/18 02:03 AM
Farmington Hills, Mich
Chuck@Best_Machine Offline
Here ya go
Re: Best way to attach windage tray inside oil pan'm sic [Re: 451Mopar] #2460311
03/03/18 02:05 AM
03/03/18 02:05 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This will work great on a fabbed or cast pan. Not a stamped one.
Re: Best way to attach windage tray inside oil pan'm sic [Re: Chuck@Best_Machine] #2460314
03/03/18 02:10 AM
03/03/18 02:10 AM
Parts unknown
Parts unknown
Originally Posted By Chuck@Best_Machine
Here ya go
Thanks Chuck, That helps me get a plan. I have a homemade custom pan
Re: Best way to attach windage tray inside oil pan'm si [Re: Dave Hall] #2460316
03/03/18 02:13 AM
03/03/18 02:13 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I have had ZERO leakes on several builds with these modern O ringed double lipped windage trays. Mancini has them. up
Re: Best way to attach windage tray inside oil pan'm si [Re: ccdave] #2460325
03/03/18 02:31 AM
03/03/18 02:31 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I never had a problem with the newer style, "double o-ring" deal either. I do know some guys that didn't have the same experience. shruggy That is a way cool deal with the tray in it!
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460336
03/03/18 02:50 AM
03/03/18 02:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mounting to the puller holes in the main caps would eventually break due to harmonics. work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best way to attach windage tray inside oil pan'm si [Re: ccdave] #2460405
03/03/18 11:24 AM
03/03/18 11:24 AM
Parts unknown
Parts unknown
That is very kool, I have never seen those before. I think I might have to try that before moving on to something else. I had a aluminum one for years I used with the big stroker crank but I'm down sizing to a 4.15 this year
Re: Best way to attach windage tray inside oil pan'm sic [Re: hemi-itis] #2460409
03/03/18 11:52 AM
03/03/18 11:52 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Yikes eek
I will be sure to remove those bolts before we go to dyno up
Thanks for the heads up thumbs
whistling
Re: Best way to attach windage tray inside oil pan'm si [Re: ccdave] #2460701
03/04/18 01:39 AM
03/04/18 01:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used the molded gasket / tray like pictured above with the Mopar Reproduction Hemi oil pan in the '69 Coronet, Seals better than anything I used before.
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460708
03/04/18 01:52 AM
03/04/18 01:52 AM
hemi-itis Offline
hemi-itis  Offline
I use a crank scraper sandwiched with an aluminum pan.Superperformance gaskets and it's dry as a bone.
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460777
03/04/18 10:48 AM
03/04/18 10:48 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run no upper windage tray or crank scraper. Charlies pan with a screen bolted in. 7100 every pass, no issues with oiling
Doug
Re: Best way to attach windage tray inside oil pan'm sic [Re: dvw] #2460782
03/04/18 11:14 AM
03/04/18 11:14 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Doug
I think the screen will have some effect, almost like a windage tray. IMHO I wouldn't run without one, at least with with any sort of stroked motor. We have a 5.0 stroke 655 that basically runs the same pan and oiling system as our 572 (4.5 x 4.5). The pan is custom, long length but shallow for ground clearance. We couldn't swap over the windage tray that we use in the 572 for obvious reasons so we ran without it in the 655. We used to lose oil pressure in the shutdown, it didn't drop to zero but it used to get low (down to 15psi). At idle, hot it's around 45psi. This never happened with the 572. We also run an accumulator. Bearings looked fine on strip down, we didn't do that many runs that season anyway but we are getting a custom tray/scraper built. I see it as cheap insurance on wet sump systems.
Re: Best way to attach windage tray inside oil pan'm sic [Re: 590 Challenger] #2460826
03/04/18 12:28 PM
03/04/18 12:28 PM
sgcuda Offline
sgcuda  Offline
Windage trays and crank scrapers need to be as close as possible to the crankshaft. Locating them deeper into the oil pan negates their purpose. Putting O rings between the block and tray or scraper will make it easier to remove the pan and tray as a single unit. If your scraper is a close fit, using dowel pins for proper location is highly recommended.
[image][/image]
