1967 GTX Tire Size Questions #2457995
02/26/18 06:39 PM
02/26/18 06:39 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Does anyone know if a 245-60-15 tire will fit on the front of a 67 GTX without anyone rubbing/clearance issues? They would be mounted on a standard 15x7 Magnum 500 which if I remember correctly has 4 1/4" backspacing. I would also like to know if a 275-60-15 would fit on the rear mounted on a 15x7 wheel. I'm pretty sure it wouldn't fit on an 8" wide wheel.
Re: 1967 GTX Tire Size Questions [Re: 1970RT] #2458011
02/26/18 07:12 PM
02/26/18 07:12 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
here is 245s and 255s on stock chrysler 7in rims.275s were too wide for tried them on a 7inch rim and they were tight and didnt look right because the tire was pulled in too much on the rim(7inch rim)
Re: 1967 GTX Tire Size Questions [Re: 1970RT] #2458012
02/26/18 07:14 PM
02/26/18 07:14 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Usually ran 2157015 or 2257015 up front.
Besides,with over 2 inches O.D. difference between the 2456015/2756015's, that would give the car too much of a front rake and more nose down--that is if you are after that look.
15x7 are a tight fit for the 275's tires and look like a bulging ballon.
The wheel vintiques 15X7 and 15x8 has 4.5" backspace
Hope this helps
Not much room out back for a 275...2556015 is best on a 15x7 rim
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 1967 GTX Tire Size Questions [Re: ogopogo] #2458016
02/26/18 07:20 PM
02/26/18 07:20 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
275s
275s
Re: 1967 GTX Tire Size Questions [Re: ogopogo] #2458021
02/26/18 07:27 PM
02/26/18 07:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
scope
Re: 1967 GTX Tire Size Questions [Re: 1970RT] #2458022
02/26/18 07:27 PM
02/26/18 07:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you go with the 4.5" BS, watch the clearance at the upper control arm ball joint area: using a 14x7 Magnum, clip-on weights interfered on my car. Using the adhesive weights on the rim barrel solved the problem. Wasn't an issue with 15 x 8 Ramcharger rims.
Re: 1967 GTX Tire Size Questions [Re: topside] #2458045
02/26/18 08:10 PM
02/26/18 08:10 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I had 245-275x60 on late '70s 15x7 w/4.25 bs steelies.
Axle was '69 4.10 Dana, 5/8" wider than the '67 4.88 Dana it came with.
275x60 fit but was very tight, had to deflate air and remove shocks to install. Another reason not to use a 275-60 it is not recommended for 7" wheel, you need a 8", I doubt it would fit.
The 245-60 fit fine on the front.
I'm going back with my original '67 Dana after I install a thin 4.10 gear. Changes will be, a 15x7 4.25 bs wheel and a 255-60 or 255-70 rear, and American Racing TT 15x6 with a 215-75 front.
Re: 1967 GTX Tire Size Questions [Re: 1970RT] #2458420
02/27/18 03:17 PM
02/27/18 03:17 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I think the question was 245's on the front.... I have 245/60-15 on the front of a 67 Charger with an 8" wheel. Slight rub on the inside frame area.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
