Re: 1967 GTX Tire Size Questions
[Re: 1970RT]
#2458012
02/26/18 07:14 PM
02/26/18 07:14 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Usually ran 2157015 or 2257015 up front. Besides,with over 2 inches O.D. difference between the 2456015/2756015's, that would give the car too much of a front rake and more nose down--that is if you are after that look.
15x7 are a tight fit for the 275's tires and look like a bulging ballon. The wheel vintiques 15X7 and 15x8 has 4.5" backspace Hope this helps Not much room out back for a 275...2556015 is best on a 15x7 rim
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 1970RT]
#2458420
02/27/18 03:17 PM
02/27/18 03:17 PM
Posts: 516 ND
dodgedon
ND
I think the question was 245's on the front.... I have 245/60-15 on the front of a 67 Charger with an 8" wheel. Slight rub on the inside frame area.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
