Harbor Freight tumbler for small rusty parts??? #2453275
02/18/18 12:20 AM
02/18/18 12:20 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
As I'm well on my way to having all of the parts for the front end cleaned/painted or powder coated, the bolts and hardware need cleaned and possibly plated.
Instead of cleaning each one with the wire wheel, I'm thinking about getting one of the tumblers to make it easier/more efficient.
Does anyone have experience with them?
What about the media needed?
There's all sorts for different jobs, I'm just looking to clean the rust and grime off the nuts and bolts.
Any advice would be much appreciated!!
Thank you!!
Wally.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2453280
02/18/18 12:29 AM
02/18/18 12:29 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have no experience with tumblers, but I do know Evaporust works great for rust removal.
Re: Harbor Freight tumbler for small rusty parts??? [Re: Neil] #2453281
02/18/18 12:33 AM
02/18/18 12:33 AM
Wisconsin
Wisconsin
I have used that before but on bigger parts and it does work fabulous!
I have some yet, maybe I should try it first??
I though I would need the tumbler for the small parts to get them reall clean???
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2453290
02/18/18 12:53 AM
02/18/18 12:53 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you do get one, try the barrel type.
I have tried the vibratory type & I am not impressed.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2453293
02/18/18 01:01 AM
02/18/18 01:01 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I have this one.
https://www.harborfreight.com/5-lb-metal-vibrator-tumbler-67617.html
It does work. I took some nasty crusty hardware and used the green resin diamond cubed media also from HFT. Stuff comes out clean without the artificially bright shine from a wheel.
NOISY as hell and not a fast process though. Its really something you have to use out in the shed far away from anyone and let it run 12-24 hours per batch depending upon how crusty things are.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2453295
02/18/18 01:10 AM
02/18/18 01:10 AM
Victoria, B.C.
P
Pat Mac Offline
Pat Mac  Offline
P
Victoria, B.C.
I have used the drum type and they work great.
I used black beauty grit and some vinegar (a mild rust remover)
I just set it down in the corner of the basement and let it do it's thing..fairly quite too.
Cheers,Pat
Re: Harbor Freight tumbler for small rusty parts??? [Re: Pat Mac] #2453317
02/18/18 01:45 AM
02/18/18 01:45 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Been using one of these for 25 + yrs,for small parts wouldn't have anything else.There is a big difference between tumbling and vibratory.
http://www.cabelas.com/product/Thumlers-...mp;gclsrc=aw.ds
Re: Harbor Freight tumbler for small rusty parts??? [Re: 62maxwgn] #2453336
02/18/18 02:45 AM
02/18/18 02:45 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
iagree
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2453833
02/19/18 11:15 AM
02/19/18 11:15 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Wet drum tumble with stainless pins, hot water, few drops of soap and as said vinegar. Rinse and dry with a hair dryer. Parts will look like new.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2457875
02/26/18 02:30 PM
02/26/18 02:30 PM
VA
dragon slayer Offline
VA
Don't you need to be careful with some of the media? Stainless rolling the threads on bolts? It works great at removing the rust, but what media are you using is probably a better question too.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2457881
02/26/18 02:39 PM
02/26/18 02:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I put a parts in plain vinegar and let them sit for 5 days last week. 1 rusty blade and a chrome bar. The blade came out bare steel like new and the vinegar ate the rust off the bar and to my surprise it ate the chrome off as well.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2457882
02/26/18 02:42 PM
02/26/18 02:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have the Harbor Freight vibratory one, works pretty well. But a while back I got myself a blast cabinet. Much quicker and I seem to like using it for some reason. I haven’t reached for the tumbler since getting the blaster, but I’m sure they both have their place.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2457920
02/26/18 04:12 PM
02/26/18 04:12 PM
Wisconsin
Wisconsin
Well, after 2 uses, the HF tumbler gave up the ghost.....
I think I'll be taking it back.
It did work good though....when it worked.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2458226
02/27/18 01:51 AM
02/27/18 01:51 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Vinegar works very well on small parts. BTDT a few hundred times. Cheap too.
Simple steps:
1. Remove all grease and loose rust with dish soap and tooth brush.
2. Immerse in vinegar. Check progress each half day or so. If part still not clean but rust can be scraped off with a knife, do so. Re-immerse. Remove when clean, a few days. Phosphated parts take a little more time to strip off the old phosphating (ignore the stink).
3. Hand wire brush all over wearing gloves. Never touch a clean part with bare fingers.
4. When part is clean and wire brushed with no fingerprints, it is ready for re-paint, re-plate, or re-phosphate. Parts that have been wire brushed will not re-rust for a few weeks or months if kept indoors in air conditioning.
Photos show parts after wire brushing. Only fasteners are shown, but this process works on other small parts just as well.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2458229
02/27/18 01:58 AM
02/27/18 01:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Some"After" photos.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2458245
02/27/18 03:11 AM
02/27/18 03:11 AM
Wisconsin
Wisconsin
WOW!!
That is some damn nice work, and great advice!
Are those parts black phosphate coated?
Thank you Kent!
Re: Harbor Freight tumbler for small rusty parts??? [Re: Alaskan_TA] #2458263
02/27/18 08:46 AM
02/27/18 08:46 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have a vibratory type.
I had poor results when I used it for the small parts on a Carter BBD rebuild.
I don't recall what media I had in it but it did clean my .38 and 9mm brass well.
Re: Harbor Freight tumbler for small rusty parts??? [Re: wkroncke17] #2458723
02/28/18 05:04 AM
02/28/18 05:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted By wkroncke17
WOW!!
Thank you Kent!
Yes, manganese phosphate, I think, from Allegheny Arsenal.
At first I tried phosphating on a propane camp stove, but found it impossible to control the temperature at 200 degrees, just below boiling. When the phosphating solution boiled, the chemicals precipitated out of solution, which didn't totally ruin it, but wasn't what's wanted.
Found a large electric fry skillet at a garage sale, and this works very well with excellent temperature control and a double stainless pot set up, a pot within a pot, as in photo.
Still used the camp stove for boiling water as a pre-heat before parts dipping in the phosphating solution.
Oiling after phosphating is recommended, but I don't think it helps much. Besides, on body bolts to be painted, you wouldn't want oil on those, which leads me to guess that original phosphated fasteners probably weren't oiled.
