Re: where did you put your proportioning valve?
[Re: J_BODY]
#2446788
02/05/18 12:56 PM
02/05/18 12:56 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Baer sells a master cylinder with the ability to mount a prop valve to the bottom of it. So in their mind it doesn't seem you can get to close to the master, they seem to know what they are doing.
68 Barracuda Formula S 340
[Re: J_BODY]
#2446891
02/05/18 03:29 PM
02/05/18 03:29 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never used one, never had to. Use the correct MC with the correct bore size and the bias built in, and plumbed correctly according to your combination (tire sizes, caliper sizes) and it just always works. If you use any old auto parts store master and don't know the bias, it's trial and error.
[Re: AndyF]
#2446959
02/05/18 05:41 PM
02/05/18 05:41 PM
Posts: 1,101 Massillon, Ohio
cudatom
Massillon, Ohio
That would make for a very nice clean set up. I too just converted to wilwood discs on front and rear after 30 yrs with stock fronts and wilwood rears.
I will have to see if I need to change out my old master cylinder. If so this may be an option.
Ok
[Re: J_BODY]
#2446998
02/05/18 06:54 PM
02/05/18 06:54 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I mounted the proportioning valve in the rear circuit. I put some rivnuts into the subframe connector and mounted the valve so that the adjustment knob just pokes through the floor between my knees when I'm driving. And I found a rubber grommet with an ID the size of the top of the prop valve housing. I slid that into the floor sheet metal and then slid the prop valve into the ID and then bolted it to the subframe connector. I'm not sure if it is really watertight since the car never sees the rain.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: J_BODY]
#2447110
02/05/18 10:35 PM
02/05/18 10:35 PM
Posts: 9,845 MI, usa
dvw
MI, usa
[Re: J_BODY]
#2447261
02/06/18 02:51 AM
02/06/18 02:51 AM
Posts: 43,205 Bend,OR USA
Cab_Burge
My street car is set up like DVW is, easy to reach BTW, don't forget to remove the residual valve from the M.C.
[Re: J_BODY]
#2447335
02/06/18 12:42 PM
02/06/18 12:42 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Jay, I'm mounting mine between the front hoop bar and the kick panel. I've moved all my lines from the engine compartment to under the dash area. Let me know if you want a picture.
[img] [/img]
[Re: dvw]
#2447338
02/06/18 12:44 PM
02/06/18 12:44 PM
clonestocker
Tucson, Arizona
Proportioner goes in the front system. Large rear drag tires will over come skinny fronts. When I first used Will Woods in 93 we wiped a pair of rotors in one season. It was the pad material. That 2nd pair of rotors were good until 2016. Two different cars, same set of rotors transfered to a faster car. Doug DVW, Why does the valve have a front and rear in port and 2 - front and 1-rear out port?
[img] [/img]
[Re: clonestocker]
#2447361
02/06/18 01:42 PM
02/06/18 01:42 PM
dvw
MI, usa
Proportioner goes in the front system. Large rear drag tires will over come skinny fronts. When I first used Will Woods in 93 we wiped a pair of rotors in one season. It was the pad material. That 2nd pair of rotors were good until 2016. Two different cars, same set of rotors transfered to a faster car. Doug DVW, Why does the valve have a front and rear in port and 2 - front and 1-rear out port? Valve has 1 in then 1 out going to the line lock. Line lock has 1 in, 2 out with 1 of them plugged as the front line T is further down. Doug
