where did you put your proportioning valve? #2446742
02/05/18 11:36 AM
02/05/18 11:36 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
I'm currently upgrading to rear disc brakes and the car has had no proportioning valve for years running a 15/16 bore Chrysler style master. I'm doing so due to the fact that I've been killing Wilwood rotors on the front after only a few events and always using the last turnouts at the tracks I attend. I'm putting a valve on the line going to the front brakes (race car only). In searching around on this there seems to be quite a difference in opinion on it's location.... Noted a few of the brake parts manufacturers recommend this. Thoughts?
Re: where did you put your proportioning valve? [Re: J_BODY] #2446746
02/05/18 11:46 AM
02/05/18 11:46 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
I mounted my adjustable prop valve on the firewall, worked just fine. Although in an effort to clean my firewall up I'm moving it to the rear just before hose that connect the brakes from body to axle.
Re: where did you put your proportioning valve? [Re: J_BODY] #2446787
02/05/18 12:54 PM
02/05/18 12:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Proportioner goes in the front system. Large rear drag tires will over come skinny fronts. When I first used Will Woods in 93 we wiped a pair of rotors in one season. It was the pad material. That 2nd pair of rotors were good until 2016. Two different cars, same set of rotors transfered to a faster car.
Doug
Re: where did you put your proportioning valve? [Re: J_BODY] #2446788
02/05/18 12:56 PM
02/05/18 12:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Baer sells a master cylinder with the ability to mount a prop valve to the bottom of it. So in their mind it doesn't seem you can get to close to the master, they seem to know what they are doing.
68 Barracuda Formula S 340
Re: where did you put your proportioning valve? [Re: J_BODY] #2446794
02/05/18 01:04 PM
02/05/18 01:04 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I have 4 wheel Disc Wilwoods. Adjustable Prop valve on rear brakes. Set it to the middle of adjustment when I installed it years ago and have never touched it. Lots of street miles and plenty of track passes.....never a stopping issue. Brake pads look great and no abnormal wear, front or rear. The idea for rear adjustable was to have front brakes with full load from master and dial up or down the rears as needed, depending on stopping quality.
Re: where did you put your proportioning valve? [Re: J_BODY] #2446845
02/05/18 02:17 PM
02/05/18 02:17 PM
AndyF Offline
AndyF  Offline
Here is the Baer master cylinder with prop valve that I'm using on my Duster project.
Re: where did you put your proportioning valve? [Re: J_BODY] #2446891
02/05/18 03:29 PM
02/05/18 03:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never used one, never had to. Use the correct MC with the correct bore size and the bias built in, and plumbed correctly according to your combination (tire sizes, caliper sizes) and it just always works. If you use any old auto parts store master and don't know the bias, it's trial and error.
Re: where did you put your proportioning valve? [Re: AndyF] #2446959
02/05/18 05:41 PM
02/05/18 05:41 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
That would make for a very nice clean set up. I too just converted to wilwood discs on front and rear after 30 yrs with stock fronts and wilwood rears.
I will have to see if I need to change out my old master cylinder. If so this may be an option.
Ok
Re: where did you put your proportioning valve? [Re: J_BODY] #2446974
02/05/18 05:59 PM
02/05/18 05:59 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Trying to attach pic...
Feb17mc
Re: where did you put your proportioning valve? [Re: J_BODY] #2446998
02/05/18 06:54 PM
02/05/18 06:54 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I mounted the proportioning valve in the rear circuit. I put some rivnuts into the subframe connector and mounted the valve so that the adjustment knob just pokes through the floor between my knees when I'm driving. And I found a rubber grommet with an ID the size of the top of the prop valve housing. I slid that into the floor sheet metal and then slid the prop valve into the ID and then bolted it to the subframe connector. I'm not sure if it is really watertight since the car never sees the rain.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: where did you put your proportioning valve? [Re: J_BODY] #2447041
02/05/18 08:04 PM
02/05/18 08:04 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
baer sells this bracket.
Re: where did you put your proportioning valve? [Re: J_BODY] #2447110
02/05/18 10:35 PM
02/05/18 10:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine
Re: where did you put your proportioning valve? [Re: J_BODY] #2447129
02/05/18 10:53 PM
02/05/18 10:53 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
That’s basically what I’m doing Doug.... and it will be on the front brakes.
Jay
Re: where did you put your proportioning valve? [Re: J_BODY] #2447261
02/06/18 02:51 AM
02/06/18 02:51 AM
My street car is set up like DVW is, easy to reach up
BTW, don't forget to remove the residual valve from the M.C. wrench grin
Re: where did you put your proportioning valve? [Re: J_BODY] #2447335
02/06/18 12:42 PM
02/06/18 12:42 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Jay, I'm mounting mine between the front hoop bar and the kick panel. I've moved all my lines from the engine compartment to under the dash area. Let me know if you want a picture.
[img] [/img]
Re: where did you put your proportioning valve? [Re: dvw] #2447338
02/06/18 12:44 PM
02/06/18 12:44 PM
Tucson, Arizona
Tucson, Arizona
Doug
DVW, Why does the valve have a front and rear in port and 2 - front and 1-rear out port?
[img] [/img]
Re: where did you put your proportioning valve? [Re: J_BODY] #2447351
02/06/18 01:10 PM
02/06/18 01:10 PM
Ohio
lockjaw-express Offline
Ohio
Can, why remove the residual valve?
I have wilwood 2 psi res. Valves installed, as I have wilwood disc brakes installed
Mark
Re: where did you put your proportioning valve? [Re: clonestocker] #2447361
02/06/18 01:42 PM
02/06/18 01:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Valve has 1 in then 1 out going to the line lock. Line lock has 1 in, 2 out with 1 of them plugged as the front line T is further down.
Doug
Re: where did you put your proportioning valve? [Re: J_BODY] #2447381
02/06/18 02:33 PM
02/06/18 02:33 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
you may want to call wildwood and check what friction rate the pads are or should be. I bought a 4 wheel disc brake kit from them a few years ago and it was eating the rear rotors, they had sent the wrong friction rate pads, changed the pads and all was good.
Re: where did you put your proportioning valve? [Re: J_BODY] #2447389
02/06/18 02:50 PM
02/06/18 02:50 PM
'murica
misfired Offline
misfired  Offline
'murica
I do proportion valve on front brakes and line lock on rear brakes. This way I match front brake power to equal the rear with bigger tires and the line lock I hit the button 1st, hit the brakes 2nd then only the front brakes will clamp on. This I feel allows a safer burnout as I can control roll out with my brakes and not just expect to roll or possibly launch forward as soon as I let go of the line lock button.
