06 liberty both codes P0440 and P0302 any ideas? #2444242
01/31/18 09:21 PM
01/31/18 09:21 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
It was throwing code P0440 a couple weeks ago, I made arrangements to take it in then it went out by itself and was gone. Dash light came on yesterday and now its throwing both codes.
Any ideas?
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444326
01/31/18 11:13 PM
01/31/18 11:13 PM
tucson az
frank Offline
frank  Offline
tucson az
Per my 06 Liberty FSM:
P0302 - Misfire detected cylinder #2
P0440 - General evaporative system failurer
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444478
02/01/18 04:08 AM
02/01/18 04:08 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My relative had the evap leak and it was the fuel pump cracked on the top.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444672
02/01/18 03:05 PM
02/01/18 03:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Codes should stay in memory so they can be retrieved & investigated.
Misfire could be tired plug or wire, maybe dirty injector; evap leak could be loose gas cap, cracked hose, etc.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444675
02/01/18 03:12 PM
02/01/18 03:12 PM
Guitar Jones Offline
Chrysler products are well known for evap and purge system hoses rotting away. Check every piece of rubber hose in those systems first.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444882
02/01/18 09:56 PM
02/01/18 09:56 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
Today I was told it was the purge valve, got one on order from Jeep for $65. Parts store had one that was $110 in stock, or Dorman that was $55 but would take 2 days. Jeep will have tomorrow. I remember on our 2001 T@C all the little pieces of hose were rotted under the battery tray.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444905
02/01/18 10:44 PM
02/01/18 10:44 PM
New York
rarefish Offline
rarefish  Offline
New York
I had the evap code on my 01 Dakota some years back and I had several hoses that had starting to crack right where they are terminated. The code came back a second time later and the caused this time was a corroded fuel filler neck.
Also a common problem in the salt belt Northern states.
