06 liberty both codes P0440 and P0302 any ideas? #2444242
01/31/18 09:21 PM
01/31/18 09:21 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
It was throwing code P0440 a couple weeks ago, I made arrangements to take it in then it went out by itself and was gone. Dash light came on yesterday and now its throwing both codes.
Any ideas?
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444326
01/31/18 11:13 PM
01/31/18 11:13 PM
tucson az
frank Offline
frank  Offline
tucson az
Per my 06 Liberty FSM:
P0302 - Misfire detected cylinder #2
P0440 - General evaporative system failurer
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444478
02/01/18 04:08 AM
02/01/18 04:08 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My relative had the evap leak and it was the fuel pump cracked on the top.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444672
02/01/18 03:05 PM
02/01/18 03:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Codes should stay in memory so they can be retrieved & investigated.
Misfire could be tired plug or wire, maybe dirty injector; evap leak could be loose gas cap, cracked hose, etc.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444675
02/01/18 03:12 PM
02/01/18 03:12 PM
Guitar Jones Offline
Chrysler products are well known for evap and purge system hoses rotting away. Check every piece of rubber hose in those systems first.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444882
02/01/18 09:56 PM
02/01/18 09:56 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
Today I was told it was the purge valve, got one on order from Jeep for $65. Parts store had one that was $110 in stock, or Dorman that was $55 but would take 2 days. Jeep will have tomorrow. I remember on our 2001 T@C all the little pieces of hose were rotted under the battery tray.
Re: 06 liberty both codes P0440 and P0302 any ideas? [Re: 71sat440] #2444905
02/01/18 10:44 PM
02/01/18 10:44 PM
New York
rarefish Offline
rarefish  Offline
New York
I had the evap code on my 01 Dakota some years back and I had several hoses that had starting to crack right where they are terminated. The code came back a second time later and the caused this time was a corroded fuel filler neck.
Also a common problem in the salt belt Northern states.
