magnum stroker truck oil pan #2443044
01/29/18 08:25 PM
01/29/18 08:25 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I have a 98 hot rod dodge truck with a stroker small block magnum i need a oil pan to clear the rods. Who makes one? Thanks John
Re: magnum stroker truck oil pan [Re: CRT] #2443077
01/29/18 09:33 PM
01/29/18 09:33 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Stock Magnum truck oil pan will.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: magnum stroker truck oil pan [Re: Adobedude] #2443092
01/29/18 10:35 PM
01/29/18 10:35 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Thats what I have, and 3&4 rods are hitting the pan.
Re: magnum stroker truck oil pan [Re: CRT] #2443173
01/30/18 01:03 AM
01/30/18 01:03 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ball peen hammer
Re: magnum stroker truck oil pan [Re: CRT] #2443483
01/30/18 04:06 PM
01/30/18 04:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
must be running stock rods?
That is the only time I had any clearance issues on one. I did just what was mentioned, little dings in I think it was the dipstick tube to get it all clearing properly. It was a balancing act for sure to get the rods to clear the tube and still get the dipstick to fit through. I think we may have slotted the bolt holes a little so we could bow out the side of the pan a tiny bit. I swore off trying to run strokers with stock rods after that and have never had a clearance issue since.
