Re: small block rocker arm clearance help needed
[Re: rumundo]
#2427311
01/01/18 06:52 PM
01/01/18 06:52 PM
Posts: 561 USA
B3RE
USA
I would have to ask, what caused the failures if cheating was a good option? I saw three Golds split the fulcrum wide open in one race weekend. They did break where they were clearanced, but that wouldn't have been necessary had the geometry been corrected. I measured for him at the track, and the shaft was .205" too low, and that was with Edelbrock RPMs. It was pounding the valvetrain like a jackhammer, and I suspect that is what happened to the adjuster side on yours also.
As far as cost of the kit and pushrods, I'd say you far exceeded that with the damage shown in those two photos. Just my observation.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2427317
01/01/18 06:58 PM
01/01/18 06:58 PM
Posts: 4,457 Washington
madscientist
Washington
As far as cost of the kit and pushrods, I'd say you far exceeded that with the damage shown in those two photos. Just my observation. If it was .205 too low how far away from the valve do you move the shaft? Don't answer that if it gives away secret stuff.
[Re: madscientist]
#2427332
01/01/18 07:25 PM
01/01/18 07:25 PM
Posts: 561 USA
B3RE
USA
As far as cost of the kit and pushrods, I'd say you far exceeded that with the damage shown in those two photos. Just my observation. If it was .205 too low how far away from the valve do you move the shaft? Don't answer that if it gives away secret stuff. It depends on a few different factors, so that's why I ask for all the measurements I do before making a kit. If it was just how much the shaft is raised, it would be a simple trig formula. Btw, I don't recall what his offset needed to be anymore. That particular case was a couple years ago.
Mike Beachel
[Re: B3RE]
#2427348
01/01/18 07:39 PM
01/01/18 07:39 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
[quote=B3RE]I would have to ask, what caused the failures if cheating was a good option? I saw three Golds split the fulcrum wide open in one race weekend. They did break where they were clearanced, but that wouldn't have been necessary had the geometry been corrected. I measured for him at the track, and the shaft was .205" too low, and that was with Edelbrock RPMs. It was pounding the valvetrain like a jackhammer, and I suspect that is what happened to the adjuster side on yours also.
I’m not arguing that you’re solution isn’t superior . Those rockers were 15 years old when they broke. The first picture is what happens when you only check for coil bind on one cylinder head🤪 My point was that clearacing the rocker was not the failure point. I agree that poor geometry could have contributed to the breakage. But... at the age of the rockers, I figured I had gotten my moneys worth out of them. They had been on a few engines and several different incarnations of this engine.
I do have a question for you. How do you move the rockershaft fore/aft as needed without the bolts being in alignment? Never saw a complete pic/ explaination on that one.
[Re: TRENDZ]
#2427373
01/01/18 08:26 PM
01/01/18 08:26 PM
Posts: 561 USA
B3RE
USA
The bolt holes in the shaft have to be elongated to allow the shafts to move laterally. It would be nice to be able to get offset shaft for a reasonable price, if at all anymore, but the bolt holes can be elongated up to .125" without reducing the wall thickness too much. For my custom T&D stuff, I can get a .050" offset shaft for long valve big block applications. Unfortunately, they don't offer them for small blocks, not even the W2 stuff.
Mike Beachel
[Re: rumundo]
#2427653
01/02/18 11:46 AM
01/02/18 11:46 AM
TRENDZ
Milwaukee WI
The real old rb stuff used those. OEM.
[Re: rumundo]
#2443178
01/30/18 01:17 AM
01/30/18 01:17 AM
madscientist
Washington
And best of all...no grinding.
