P4532795 sb heads? #2440438
01/25/18 08:52 AM
01/25/18 08:52 AM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
A friend has a set of unfinished cylinder heads. P4532795, what are they, he doesn't know?
Re: P4532795 sb heads? [Re: quickd100] #2440450
01/25/18 10:54 AM
01/25/18 10:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
for the most part with any Mopar stuff.... if that's a number cast in the head it might just be that. Most of the time the number on the box or paperwork would actually reference as to "what it is".
Re: P4532795 sb heads? [Re: quickd100] #2440457
01/25/18 11:10 AM
01/25/18 11:10 AM
nielsville, minn.
Q
Q
nielsville, minn.
No box or paperwork with them. The numbers are stamped on the end of the heads. They are raw unfinished castings.
Re: P4532795 sb heads? [Re: quickd100] #2440459
01/25/18 11:10 AM
01/25/18 11:10 AM
nielsville, minn.
Q
Q
nielsville, minn.
Re: P4532795 sb heads? [Re: quickd100] #2440466
01/25/18 11:25 AM
01/25/18 11:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
guess I was "assuming" iron.... are they aluminum? there was a run of "commando" aluminum heads back in the day. We have some MP iron heads on our 360, but no number on the ends of the castings.
Re: P4532795 sb heads? [Re: quickd100] #2440485
01/25/18 12:12 PM
01/25/18 12:12 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: P4532795 sb heads? [Re: quickd100] #2440493
01/25/18 12:33 PM
01/25/18 12:33 PM
nielsville, minn.
Q
Q
nielsville, minn.
Yep aluminum, raw castings, nothing drilled, no bolt holes, guides, or seats.
Re: P4532795 sb heads? [Re: quickd100] #2440549
01/25/18 02:13 PM
01/25/18 02:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I saved a metric ____-ton of information when I left MP, including every historic casting chart I could get my hands on. Filed away in the basement. Want me to check when I get home?
(holler at me on social media, I check in here maybe once a week)
It's been suggested in the past to make a
book out of that info and sell the book laugh2
Rich H.
Esse Quam Videri
Re: P4532795 sb heads? [Re: quickd100] #2440561
01/25/18 02:41 PM
01/25/18 02:41 PM
nielsville, minn.
Q
Q
nielsville, minn.
That would be great Rich
Re: P4532795 sb heads? [Re: quickd100] #2440579
01/25/18 03:39 PM
01/25/18 03:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Cool, that will help me remember.
Rich H.
Esse Quam Videri
Re: P4532795 sb heads? [Re: quickd100] #2440828
01/26/18 01:48 AM
01/26/18 01:48 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Large Port Commando Head
Kick here and scroll down to the cylinder head fit section.
http://www.ttiexhaust.com/MoparClassics-Headers/340W2/TTi340W2.htm
Picture below:
http://www.ttiexhaust.com/MoparClassics-Headers/340W2/CommandoP4532795.jpg
Re: P4532795 sb heads? [Re: quickd100] #2440893
01/26/18 08:45 AM
01/26/18 08:45 AM
nielsville, minn.
Q
Q
nielsville, minn.
Thanks for the info!
Re: P4532795 sb heads? [Re: quickd100] #2747978
03/01/20 11:14 AM
03/01/20 11:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
QuickD... so your “friend” must have gone to March Meet a couple years ago smile.
Re: P4532795 sb heads? [Re: J_BODY] #2748018
03/01/20 02:02 PM
03/01/20 02:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Those look like an excellent candidate for “how to spend 3-4 times on cylinder heads than what they’re worth”.
Re: P4532795 sb heads? [Re: fast68plymouth] #2748034
03/01/20 03:19 PM
03/01/20 03:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well.... we are mopar guys Dwayne! laugh2
I thought saw em in two and have some really cool wheel chocks....
Re: P4532795 sb heads? [Re: J_BODY] #2748038
03/01/20 03:29 PM
03/01/20 03:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
Unless someone had a cnc program for that casting, to do all the normal machining on them(all the bolt holes, rocker stands, guide and seat bores, vc rail, basic milling), and wouldn’t charge a fortune for that...... and there were an affordable option for cnc porting as well...... if those two conditions can’t be met(along with someone just having to have them).... then, “IMO”...... they are only worth what they weigh for scrap.
Or, like you say....... conversational wheel cocks.
Re: P4532795 sb heads? [Re: fast68plymouth] #2748076
03/01/20 05:26 PM
03/01/20 05:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Id say just the opposite. I wish I could buy parts in that condition. Nothing removed from any areas that the oem dictates need to be removed. Pushrod pinch, valve angles, seat angles, chamber shape, rocker stand placement, etc...
Re: P4532795 sb heads? [Re: TRENDZ] #2748078
03/01/20 05:53 PM
03/01/20 05:53 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Place an add in the want ad section, time to tool up. Since your gonna be bug deep in these heads you shouldnt mind a modest buy in for the castings and people got them.
So what ya gonna put them on?
STOP POTATO HATE!
Re: P4532795 sb heads? [Re: Mr PotatoHead] #2748118
03/01/20 07:42 PM
03/01/20 07:42 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I stumbled across this post looking for info on another “P” head... when I was at March Meet 2 years ago these raw casting were in the swap area and I know the seller was from MN. I’m sure they’re the same ones the OP was talking about. While basically worthless, it’d be interesting to know their story....
Re: P4532795 sb heads? [Re: Mr PotatoHead] #2748424
03/02/20 09:50 PM
03/02/20 09:50 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I should have been more clear... not these specific heads, but any head / block I would want. The best example I could come up with would be the B engine stage 6. The raw casting has so much potential. They ruined them with the pushrod holes, the spring seat location, the rocker stand positions etc...
Then another thing that comes to mind is the Original ritter block. Let me buy a casting. I’ll put the machined areas where I want them, not worrying about errors or unneeded Machine operations. Seems to me that the wait and errors of machining are the hurdles that keep blocks from making it to market. I realize that I am in a small minority of buyers, but why not offer raw castings as an option. Heck, you could even use it as an advertisement advantage... “Blocks starting at $1500! Available now!“
