P4532795 sb heads?
#2440438
01/25/18 08:52 AM
01/25/18 08:52 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
A friend has a set of unfinished cylinder heads. P4532795, what are they, he doesn't know?
Re: P4532795 sb heads?
[Re: quickd100]
#2440485
01/25/18 12:12 PM
01/25/18 12:12 PM
Posts: 13,589 md
mopars4ever
md
[Re: quickd100]
#2440493
01/25/18 12:33 PM
01/25/18 12:33 PM
quickd100
nielsville, minn.
Yep aluminum, raw castings, nothing drilled, no bolt holes, guides, or seats.
[Re: quickd100]
#2440549
01/25/18 02:13 PM
01/25/18 02:13 PM
Posts: 17,845 S.E. Michigan
ZIPPY
S.E. Michigan
I saved a metric ____-ton of information when I left MP, including every historic casting chart I could get my hands on. Filed away in the basement. Want me to check when I get home? (holler at me on social media, I check in here maybe once a week) It's been suggested in the past to make a book out of that info and sell the book
Rich H.
Esse Quam Videri
[Re: quickd100]
#2440579
01/25/18 03:39 PM
01/25/18 03:39 PM
ZIPPY
S.E. Michigan
Cool, that will help me remember.
Rich H.
Esse Quam Videri
[Re: J_BODY]
#2748018
03/01/20 02:02 PM
03/01/20 02:02 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Those look like an excellent candidate for “how to spend 3-4 times on cylinder heads than what they’re worth”.
[Re: fast68plymouth]
#2748034
03/01/20 03:19 PM
03/01/20 03:19 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Well.... we are mopar guys Dwayne! I thought saw em in two and have some really cool wheel chocks....
[Re: J_BODY]
#2748038
03/01/20 03:29 PM
03/01/20 03:29 PM
fast68plymouth
So. Burlington, Vt.
Unless someone had a cnc program for that casting, to do all the normal machining on them(all the bolt holes, rocker stands, guide and seat bores, vc rail, basic milling), and wouldn’t charge a fortune for that...... and there were an affordable option for cnc porting as well...... if those two conditions can’t be met(along with someone just having to have them).... then, “IMO”...... they are only worth what they weigh for scrap.
Or, like you say....... conversational wheel cocks.
#2748076
03/01/20 05:26 PM
03/01/20 05:26 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Id say just the opposite. I wish I could buy parts in that condition. Nothing removed from any areas that the oem dictates need to be removed. Pushrod pinch, valve angles, seat angles, chamber shape, rocker stand placement, etc...
[Re: TRENDZ]
#2748078
03/01/20 05:53 PM
03/01/20 05:53 PM
Posts: 9,456 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Place an add in the want ad section, time to tool up. Since your gonna be bug deep in these heads you shouldnt mind a modest buy in for the castings and people got them. So what ya gonna put them on? Id say just the opposite. I wish I could buy parts in that condition. Nothing removed from any areas that the oem dictates need to be removed. Pushrod pinch, valve angles, seat angles, chamber shape, rocker stand placement, etc...
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2748424
03/02/20 09:50 PM
03/02/20 09:50 PM
TRENDZ
Milwaukee WI
Place an add in the want ad section, time to tool up. Since your gonna be bug deep in these heads you shouldnt mind a modest buy in for the castings and people got them. So what ya gonna put them on? Id say just the opposite. I wish I could buy parts in that condition. Nothing removed from any areas that the oem dictates need to be removed. Pushrod pinch, valve angles, seat angles, chamber shape, rocker stand placement, etc... I should have been more clear... not these specific heads, but any head / block I would want. The best example I could come up with would be the B engine stage 6. The raw casting has so much potential. They ruined them with the pushrod holes, the spring seat location, the rocker stand positions etc... Then another thing that comes to mind is the Original ritter block. Let me buy a casting. I’ll put the machined areas where I want them, not worrying about errors or unneeded Machine operations. Seems to me that the wait and errors of machining are the hurdles that keep blocks from making it to market. I realize that I am in a small minority of buyers, but why not offer raw castings as an option. Heck, you could even use it as an advertisement advantage... “Blocks starting at $1500! Available now!“
