Re: Best head porting shops
[Re: jkwedge540]
#2435943
01/16/18 10:11 PM
01/16/18 10:11 PM
Posts: 3,105 Michigan
A727Tflite
Dwayne Welder in Michigan. Worked at many of the best shops in Michigan, raced with some of the best Super Stock guys in the 70's and 80's,
Is 2nd to none for hand porting.
[Re: hemi-itis]
#2436108
01/17/18 01:52 AM
01/17/18 01:52 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree as Dwayne Porter did awesome work on my heads and cam. And every car I see with some of his work done to it runs great. Ron
[Re: jkwedge540]
#2436121
01/17/18 02:38 AM
01/17/18 02:38 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Dwayne Porter does exceptional work. High quality and attention to detail seldom seen these days.
[Re: jkwedge540]
#2436148
01/17/18 04:02 AM
01/17/18 04:02 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
What does "soften the chambers mean"?
[Re: jkwedge540]
#2436237
01/17/18 12:15 PM
01/17/18 12:15 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I'm a huge fan of Dwayne Porter's, but I'm not sure he does any chamber softening. Look at Buck's Racing engines in NC, Slawko, or Hemphill up there by you in PA.
Cab...it's a modification (enlarging) to the combustion chamber making it more nitrous friendly.
[Re: an8sec70cuda]
#2436257
01/17/18 12:38 PM
01/17/18 12:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Cab...it's a modification (enlarging) to the combustion chamber making it more nitrous friendly. Chip, I think your correct on this one. Dwayne doesnt do a ton of nitrous stuff, nor a ton of B1's, doesnt mean he woudnt, I am sure he will chime in here and advise. If he doesnt or cant, I like 2 on your list for that. 1) Slawko 2) Bucks Not sure if Brandywine is still around,Speier,Carl Fults etc, Do a little research with the nitrous guys and you'll see, but I think Buck and Slawko are two good choices. Monte Smith used to like Bucks work.
RIP Monte Smith
[Re: Cab_Burge]
#2436263
01/17/18 12:49 PM
01/17/18 12:49 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
What does "soften the chambers mean"? It's a very shallow, slightly angled concave cut on the quench pad area of the chamber. It makes the engine less timing sensitive and opens up the tuning window on heavy nitrous or boosted applications.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: jkwedge540]
#2436296
01/17/18 01:31 PM
01/17/18 01:31 PM
fast68plymouth
So. Burlington, Vt.
I'm a huge fan of Dwayne Porter's, but I'm not sure he does any chamber softening. Chip and Todd are correct. I appreciate the confidence, but that type of work is a little out of my wheelhouse.
[Re: Runnoft]
#2436364
01/17/18 03:57 PM
01/17/18 03:57 PM
Cab_Burge
What does "soften the chambers mean"? It's a very shallow, slightly angled concave cut on the quench pad area of the chamber. It makes the engine less timing sensitive and opens up the tuning window on heavy nitrous or boosted applications. Thanks ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I leaned something new today ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
