Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2433297
01/12/18 11:38 AM
01/12/18 11:38 AM
Posts: 9,873 MI, usa
dvw
MI, usa
True that. Would not be surprised if he added ballast to certain sections of the rear. I believe those pups already have aluminum hoods. I suspect most of the weight is in the doors, interior and dash bulkhead section. It would be a challenge to narrow down the weight of a street Challenger. A friend has a new style Challenger drag car. Full dash, door panels, interior trim, power windows, 6.1 N/A, 904, 8 3/4, all stock body. Less than 3100 w/o driver. Looks bone stock except for the seats. Doug
[Re: Thumperdart]
#2434879
01/15/18 08:33 AM
01/15/18 08:33 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I know I have used some of this thread for ideas on my 2005 ram
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
#2435090
01/15/18 05:25 PM
01/15/18 05:25 PM
Posts: 4,700 Wichita
GY3
Wichita
Anything painted black will conceal it better to the naked eye except of course, if you are talking auto body panel work using a gloss black. Flat or satin black tends to be more stealthy. The look a sheen of aluminum draws the eye to it and basically opens up the flood gates of curiosity and questions. Black draws heat to itself so theoretically it should keep the radiator a tiny cooler because it will extract the heat from within to the outside where the black is at. Old Nascar trick supposedly utilizing pigment thermo physics. The part about "drawing the eye" is so true. One weekend I put on a Moroso underdrive pulley and left it aluminum thinking no one would notice. THE FIRST GUY that walked by at our cruise in commented on the pulley! It came off and got draped in black the next day!
[Re: Thumperdart]
#2437046
01/18/18 08:24 PM
01/18/18 08:24 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
Well I need to find some where to lose a little weight cause I'm swapping my stock brake lines for stainless as soon as the weather breaks here. Have I mentioned I'm over winter?
eBay-cdwmotorsports
[Re: Thumperdart]
#2437744
01/19/18 11:59 PM
01/19/18 11:59 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Now Jenny Craig has to travel further with his feather "B" ENGLISHTOWN IS DEAD ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif)
[Re: moparx]
#2437926
01/20/18 01:42 PM
01/20/18 01:42 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
when you get to re-doing the wiring, any idea if you will be removing any unnecessary circuits, or just tiding up ? 2-3 pounds there, or does it just look worse that it really is ? I've been on him for a while about the wiring in that thing! Probably won't quite add up to 2-3 lbs, there's not much there to begin with. Depends how far he wants to go though. Once I get my own car out of storage, I have to finish the wiring in it. I removed a bunch of unnecessary circuitry just leaving the bare minimum. Of course I did it the hard way trying to adapt the factory harness to a generic fuse panel, not the easiest method.
'71 Duster '72 Challenger '17 Ram 1500
[Re: moparx]
#2437988
01/20/18 04:14 PM
01/20/18 04:14 PM
fullmetaljacket
Here's my front STEEL wheels without their respective hub caps. These were the very first Centerline Stealth (or what ever they are called) wheels off the line and were being shown at SEMA at their booth. I couldn't believe my eyes when I saw that a company had semi built a line of wheels that would look close to a stock wheel. They at the time were surprised themselves that someone was going google eyed over a plain innocent looking wheel. They saved a total of 12 Lbs over the skinny steelies I had for years. Could save much more over a set of standard 6" or 7" steel wheels for sure. Not much in some circles literally, but never the less, less pounds up front.
#2437991
01/20/18 04:21 PM
01/20/18 04:21 PM
fullmetaljacket
Wow, I've posted flicks of my aluminum column so far back on this thread, the thread may have to start all over in order for dudes to keep up. LOL.
Here's the column sitting up next to the stock puppy. It saved about 3 Lbs IIRC. Everything stock including adding a lightweight Bondo Bob's steering shaft fit into it.
#2437996
01/20/18 04:28 PM
01/20/18 04:28 PM
fullmetaljacket
Here's a detail from the head mast. Some cats in a machine shop located in the Brooklyn Navy Yard where I was building the car in secret turned this on their lathe one afternoon while on their lunch break. LOL. I did the final shaping of holes, filing and drilling by hand.
