INITIAL SHOCK SET UP................. #2429430
01/05/18 01:51 PM
01/05/18 01:51 PM
State of confusion
Thumperdart Offline OP
State of confusion
Jason Pettis turned down the upper and lower stock shock stud mounts to .0480 to fit in the heims on the Vikings and I made a bottom plate to raise em up 1 1/4 inches since they were a tad shorter than the Ranchos. So, being they have 6 in of travel I was thinking 1 1/2- 1 3/4 compression and the rest extension, sound right............. thumbs
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429450
01/05/18 02:50 PM
01/05/18 02:50 PM
gregsdart Online content
gregsdart  Online Content
Dom, if you expect a lot of extension on the hit, you could start there. Something made up to check max travel in both directions, like a rod with gromets on it and something attached to the axle end of the shock mount to push those gromets could tell you a few things.
Re: INITIAL SHOCK SET UP................. [Re: gregsdart] #2429456
01/05/18 03:17 PM
01/05/18 03:17 PM
State of confusion
State of confusion
The Ranchos had 2 1/4 compression and less than 4" of extension and had no issues using the tie wrap test for both extension and compression on the street so being these will be tighter, I will go w/the 1 3/4 then.........Thankxxx................ beer
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429488
01/05/18 04:17 PM
01/05/18 04:17 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Dom you have leaf springs correct?
Leafs tend to rise = body separation more than ladders or 4 links IMHO.
IIRC you have calverts bars on. Do they have less body separation than say SS springs?
Are you still looking for SA front shocks?
Don
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429497
01/05/18 04:32 PM
01/05/18 04:32 PM
With six inches of rear shock travel I have set them at two inches from bottomed out (1/3 travel) at static ride height per instructions from Penske years ago on Skips car up
I have talk to several other shock companies about the initial ride height and they all basically said the same thing on a street and strip drag car shruggy
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429519
01/05/18 05:24 PM
01/05/18 05:24 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Dom likely little reason to need much more compression on your deal. Except maybe when seeing street duty. Our Camaro is mostly street driven and we have 1.5" com compression on the shocks and every once in awhile on the highway it will bottom out. I am willing to live with that. FWIW it is a Caltrac/mono leaf car as well. If it was more a street car I'd want more but IMO you will be fine. You need all the extension you can get with that set up.
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429527
01/05/18 05:31 PM
01/05/18 05:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Are the shocks mounted straight up & down or like factory angled ? an angled shock travels less VS suspension travel than a straight up & down mount, just sayin smile
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429564
01/05/18 06:56 PM
01/05/18 06:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
6" is pretty short for a leaf spring car...
The shocks move MORE when they are mounted on an angle...not less, but not by a ton.
Depends on the angle...if you had 30 degrees, every 1.73" of vertical travel = 2" of travel along the angle. Less angle means less difference. So in the end it's not a huge deal, but might make or break you with a short shock.
Re: INITIAL SHOCK SET UP................. [Re: dizuster] #2429573
01/05/18 07:10 PM
01/05/18 07:10 PM
State of confusion
State of confusion
Shocks are straight up n down and yes on the Caltracs...........Going to mount em now and see where we're at so thankxxx guys next is DA Vikings on the front then track time there after............ boogie drive beer
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429579
01/05/18 07:20 PM
01/05/18 07:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's going to drag the bumper
Re: INITIAL SHOCK SET UP................. [Re: Al_Alguire] #2429589
01/05/18 07:51 PM
01/05/18 07:51 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
iagree but Al come on I really believe the Camaro stuff is offtopic hahaha..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: INITIAL SHOCK SET UP................. [Re: WHITEDART] #2429591
01/05/18 07:53 PM
01/05/18 07:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Oh I have to apologize I just remember the thumper runs bowtie rear suspension
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429595
01/05/18 08:03 PM
01/05/18 08:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: INITIAL SHOCK SET UP................. [Re: WHITEDART] #2429606
01/05/18 08:25 PM
01/05/18 08:25 PM
State of confusion
State of confusion
Hows that Mr. "FORD" rear suspension...............lol They are installed and I have a tad over 2" of compression so soon we will see what this lipstick pig will run............... biggrin beer
Re: INITIAL SHOCK SET UP................. [Re: Al_Alguire] #2429719
01/06/18 12:54 AM
01/06/18 12:54 AM
State of confusion
State of confusion
Al, I drive this thing almost weekly and have for many months that's why she's wore out....... laugh2
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429777
01/06/18 03:40 AM
01/06/18 03:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
And Don't Forget about adding Preload to the passenger side rear since in the vids your crushing the rear driver side tire and the passenger side tire appears to be floating, since you took that extra batt out of the rear.
You did do 3 changes though to lose your 60 ft. from 1.30 to 1.40
Batt remove.
Slick change.
Carb change.
Don't you know the rule of thumb, Change 1/one thing at a time, Cab and Pettis should of drilled that in your head by now.
Now, based on the blurry vids, your axel is rotating down on the driver side and up on the passenger side. Exactly how physics would have it do. Keep that into consideration after your initial mechanical shock set up. up
Re: INITIAL SHOCK SET UP................. [Re: Sport440] #2429782
01/06/18 03:57 AM
01/06/18 03:57 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You got the blurry vids part right! laugh No seriously, good call!
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2429882
01/06/18 01:27 PM
01/06/18 01:27 PM
Las Vegas
Las Vegas
Hey now my Camaro has hybrid rear suspension Dana 60 and Caltracs. Did I mention its Panther Pink too smile Given those two items I feel its always on topic here
Dom I know you do and I know those beautiful Cali roads. We used to drive the Camaro 55 miles on I80 to get to Sac Raceway and rarely had an issue, you'll be fine as far as compression goes. 6" of travel is NOT a ton but IMO will probably be sufficient. Camaro only has 5 and its been 9.70's with its pump gas pig
Re: INITIAL SHOCK SET UP................. [Re: Sport440] #2429891
01/06/18 01:45 PM
01/06/18 01:45 PM
State of confusion
State of confusion
Batt remove.
Slick change.
Carb change.
I agree w/you on these things and have watched the "blurry" vid several times and see the same thing, the axle is teeter tottering and the truck shocks, soft sidewall tires and battery removal made it worse. 2nd batt is back, new bad ass shocks ft and rear and we will let er eat............The carb works great but does need some more street testing which I will do before we head back out in a couple of weeks......... beer thumbs New goal; 1.29 60 ft. 6.000 et at 113+ mph.............. drive
Re: INITIAL SHOCK SET UP................. [Re: Thumperdart] #2430471
01/07/18 01:43 PM
01/07/18 01:43 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Swing by so that we can finish up a 8.50 cert cage. Bring plenty of beer. Pizza is only around the corner.
[image][/image]
