Hood Hinges - one side "pops up" when closing. #242831
03/04/09 12:12 PM
03/04/09 12:12 PM
Friendsville, TN
Reverend_Ron Offline OP
super street
super street
Friendsville, TN
What causes this and what is the fix?
Thanks,
Ron
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242832
03/04/09 12:52 PM
03/04/09 12:52 PM
Chicagoland
chargerron69 Offline
Chicagoland
had it happen to me a couple times you need a new hinge
does the hood come down sideways over the opposite fender?
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Hood Hinges - one side "pops up" when closing. [Re: chargerron69] #242833
03/04/09 01:21 PM
03/04/09 01:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
worn holes and rivets.
fix.. bushing on holes and/or replace rivets with oversizeds ( if available ) needing a prior rounding job on hinge holes.
I'm on same deal. I bet is Driver side LOL
Re: Hood Hinges - one side "pops up" when closing. [Re: NachoRT74] #242834
03/04/09 02:00 PM
03/04/09 02:00 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
try adjusting the hood first
Re: Hood Hinges - one side "pops up" when closing. [Re: aarcuda] #242835
03/04/09 02:05 PM
03/04/09 02:05 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think there is somone on here that has a rebuild servise for the hinges. Try doing a seach for it.
Re: Hood Hinges - one side "pops up" when closing. [Re: chargerron69] #242836
03/04/09 02:17 PM
03/04/09 02:17 PM
Friendsville, TN
super street
super street
Friendsville, TN
Yes it does! And yes, the drivers side; two separate cars, same side.
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242837
03/04/09 03:29 PM
03/04/09 03:29 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Hi Ron,
I don't know what kind of car you have, but
generally this is a worn pin and/or sloppy teeth problem that allows the back of the hood to walk up. You can grab the back edge of the hood and push up/down to see how much movement you're getting. If you can get a view of the hinge while you do this, you'll see the slop in the teeth mesh allowing the upward movement; worn pins can contribute, but usually it's time for some dental work..
Yes, I'm the hood hinge rebuilder guy..
Rick
Re: Hood Hinges - one side "pops up" when closing. [Re: RestoRick] #242838
03/04/09 03:49 PM
03/04/09 03:49 PM
Friendsville, TN
super street
super street
Friendsville, TN
1971 Chargers. I'll investigate the hinges more in detail and check out your website!
Thanks.
68 Roadrunner, 383,4-spd 71 Superbee, Citron Yella, 383,slapstick 71 Charger 500, Autumn Bronze, 383,4-spd, A/C 72 Imperial, 2-dr hdtp 74 Charger SE, 440-auto, sunroof 84 Crew Cab Dually, 440-auto 01 Quad Cab Dually, HO Cummins;6-spd 08 H-D, Softail Custom 08 Challenger, 6.1 Hemi
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242839
03/04/09 04:47 PM
03/04/09 04:47 PM
IA
landon1 Offline
landon1  Offline
IA
same problem with the 71 satellite - my hood doesn't walk over to the driver's side, it just doesn't go down all the way on rear pass side
'71 Satellite Sebring 440
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242840
03/04/09 05:25 PM
03/04/09 05:25 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Thanks,
Ron
My 66 Coronet hood was perfect and then one day the passenger side started sticking up after closing. It turned out the hinge plate bolted to the inner fender had cracked.
Re: Hood Hinges - one side "pops up" when closing. [Re: landon1] #242841
03/04/09 05:27 PM
03/04/09 05:27 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Speaking of hood hinges... Mine must need some Viagra.
The hood on my 71 Road Runner opens and closes fine. However, the hood does NOT like to stay up. If the hood is up and I start the car, it'll come crashing down before I can even get out of the car and back out front. What's up with that? Are these "new" E-body hood hinges the same? If so, I just might buy a new pair. Car is apart for engine compartment paint anyway... Now would be the perfect time to fix said issue.
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242842
03/04/09 05:57 PM
03/04/09 05:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
3 separate cars and in another country LOL. Mine is a later one without teeth
Re: Hood Hinges - one side "pops up" when closing. [Re: pinkduster] #242843
03/04/09 06:47 PM
03/04/09 06:47 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Loose pins are the problem & I'd be real surprised if the teeth weren't worn badly as well.
The repro E-bodies will fit your 71 B-body, but are slightly different on the base dimensions. I haven't had a set of these to look at yet to see how well they're made; I have my doubts about the teeth fit. They're modeled after the 71-2 style Ebody hinge.
Rick
Re: Hood Hinges - one side "pops up" when closing. [Re: pinkduster] #242844
03/04/09 08:19 PM
03/04/09 08:19 PM
Friendsville, TN
super street
super street
Friendsville, TN
I vaguely remember someone telling me once that hinges are different too - meaning that flat hood hinges weren't as strong as say Air Grabber hinges. So if you had a flat hood car, added an Air Grabber hood - the hinges wouldn't hold the hood up. Maybe THIS is your dilemma...
Re: Hood Hinges - one side "pops up" when closing. [Re: Reverend_Ron] #242845
03/04/09 08:30 PM
03/04/09 08:30 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I remember some talk on hear about that maybe a year ago or more, but I didn't think anything was confirmed. Plus, I have never seen anyone selling Air Grabber... No wait, let me get it right... "N96" hood hinges. If the hinges were different, you can bet your A$$ that someone would be selling used ones labeled as such for 10 times the cost of "flat hood" hinges.
Re: Hood Hinges - one side "pops up" when closing. [Re: pinkduster] #242846
03/04/09 08:49 PM
03/04/09 08:49 PM
WI
RestoRick Offline
RestoRick  Offline
WI
It's the springs that are different... same hinges.
But in my experience, rebuilt tight hinges will stay up with either springs.
Rick
Re: Hood Hinges - one side "pops up" when closing. [Re: pinkduster] #242847
03/04/09 09:20 PM
03/04/09 09:20 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Have that same problem when I put an R/T hood on a regular charger.. that added alot of weight... The springs are supposed to be different... according to Ma mopar.. 71& 72 coronet & charger "Sport & fresh air hood" springs should be part #3586094, compared to regular 2 door hoods which use spring # 3586092. 4 door springs are # 3586093. Under the plymouth section 71 &72 satellite 2 door springs would be 3586088 and 4 doors used springs 3586093.. That plymouth stuff doesn't exactly make sense.
You should be happy with some 3586094 springs, if you could find them....
