Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: Most Powerfull 59 Degree Small Block Ever? [Re: Leigh] #24267
08/16/09 10:01 AM
08/16/09 10:01 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Laverne who??
not the guy with the kickazz 48* w/7/8 motor??
dak, I am sure you read my post as you went on to use it in quotes, there are/were many 59* sbm's faster then mine. But at the time it was built 9 years ago it was pretty stout...
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24268
01/06/10 02:38 PM
01/06/10 02:38 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
BUMP!!
Re: Most Powerfull 59 Degree Small Block Ever? [Re: DavidDean] #24269
01/06/10 02:41 PM
01/06/10 02:41 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
That was on my list.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: S/ST 3040] #24270
01/06/10 03:08 PM
01/06/10 03:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
OK
How about my friends small block. I have seen it stomp a few stroker big blocks with roller cams and aluminum heads. Anyways
Its a 4" stroke, stock 340 block, Cast iron W2's, compression is 13.5:1 or so. He runs a Indy Intake, no Dominator, just a 850 Holley HP, shelf TTI headers, Solid Flat tappet cam in the 260's at .050 range with .650-.670 lift area. Comp Cams Bee Hive valve springs. Small tire, leaf spring 68 Dart with Cal tracks. It make 630HP on a Dyno that has a reputation for being on the stingy side. He shifts it at 6700 rpms. Has 4.56 gears and 29x 10.5 tires. The car weighs 3150-3200 lbs with driver.
He runs consistent high 6.20's in the heat in the 8th mile.
He runs this car at about every Chrysler Classic show, and probably pus 250 passes a year on it..The motor is getting freshen'd by my guy (he built the motor also), and they said they found another 30-40 hp and 500-600 more usable RPM. Still going to use a flat tappet, and still wont have a dominator.
Id say if he would add a roller cam, and a Dominator he would be above 650 easy on the same Dyno, and would put him in the 9.70 range in the quarter mile.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: S/ST 3040] #24271
01/06/10 10:31 PM
01/06/10 10:31 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
Funny how this post keeps coming back, Right VIC
Re: Most Powerfull 59 Degree Small Block Ever? [Re: johnnyp] #24272
01/06/10 10:47 PM
01/06/10 10:47 PM
S/ST 3040 Offline
S/ST 3040  Offline
Reckon it's right popular.
I go back and read through it from time to time.
I didn't find where I'd too much.
BTW, my phone still rings.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: S/ST 3040] #24273
01/06/10 11:08 PM
01/06/10 11:08 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
a mate has a 408 ,hand ported indy-2 runs 9.1@145 in 2760 car
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Most Powerfull 59 Degree Small Block Ever? [Re: johnnyp] #24274
01/06/10 11:42 PM
01/06/10 11:42 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
i was thinking the same...
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB449VALIANT] #24275
01/07/10 12:17 AM
01/07/10 12:17 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Wow it doesn't go away
Re: Most Powerfull 59 Degree Small Block Ever? [Re: B1KILLER] #24276
01/07/10 02:15 AM
01/07/10 02:15 AM
Edmonton alberta Canada
mr. 63plymouth Offline
Mine make 749hp at the flywheel and 638 torque with a 340 resto block(59degree)single 750 carb,pump gas,No power adders!!!! 1/3/4" headers threw full exhaust and interior with a 10" tire,car went 9.52@142.81mph.
461 cubic inch SMALL BLOCK!!!
Re: Most Powerfull 59 Degree Small Block Ever? [Re: mr. 63plymouth] #24277
01/07/10 02:59 AM
01/07/10 02:59 AM
Mcallen, TX
Mcallen, TX
Mine make 749hp at the flywheel and 638 torque with a 340 resto block(59degree)single 750 carb,pump gas,No power adders!!!! 1/3/4" headers threw full exhaust and interior with a 10" tire,car went [Email]9.52@142.81mph.[/Email]
1 3/4 headers, etc. what`s your race weight? Is great to see a real 59* engine making some decent power....
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB449VALIANT] #24278
01/07/10 03:34 PM
01/07/10 03:34 PM
3050lbs down the track. Thanx
