Aluminum motor growth #2426895
01/01/18 01:59 AM
01/01/18 01:59 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
If an iron block aluminum head growth is roughly .006 what might one expect out of an all aluminum engine?
Re: Aluminum motor growth [Re: sixpackgut] #2426905
01/01/18 02:20 AM
01/01/18 02:20 AM
Washington
madscientist Offline
Washington
I've seen .014-.018
Re: Aluminum motor growth [Re: sixpackgut] #2426959
01/01/18 06:51 AM
01/01/18 06:51 AM
Sydney Australia
sr440 Offline
sr440  Offline
Sydney Australia
They don't grow Ray. They expand........ If they were to grow they would get old............
Re: Aluminum motor growth [Re: sr440] #2426986
01/01/18 11:13 AM
01/01/18 11:13 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
they do get old.i have al block and heads,just the valve lash grows from 8 thou to 20 thou.
Re: Aluminum motor growth [Re: bonefish] #2426987
01/01/18 11:31 AM
01/01/18 11:31 AM
NY
challenger451ci Offline
NY
My Indy Maxx with SR heads grows about 0.0.020" at temp. Indy told me the deck height would change about 0.010" at 170F. With a 1.7 rocker, that's ~0.017" lash change.
Re: Aluminum motor growth [Re: challenger451ci] #2427000
01/01/18 12:20 PM
01/01/18 12:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That's about what we see...
Re: Aluminum motor growth [Re: sixpackgut] #2427658
01/02/18 11:53 AM
01/02/18 11:53 AM
an8sec70cuda Offline
My KB block/MP head hemi grows about .013" cold to hot. I lash the valves at .010" cold for .023" hot.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum motor growth [Re: sixpackgut] #2427690
01/02/18 12:58 PM
01/02/18 12:58 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
when I read " Indy told me the deck height would change about 0.010" at 170F. With a 1.7 rocker, that's ~0.017" lash change." My 1st thought is "doesn't your pushrods and valves expand also?" I know that the valves and the pushrods don't expand as much as the block (steel vs Al) but they do expand. Which is why if you run a iron block and iron head the clearance tightens up a few thousands. (iron vs steel)
Joe
Without Data, you’re just another guy with an opinion.
Re: Aluminum motor growth [Re: sixpackgut] #2427748
01/02/18 02:54 PM
01/02/18 02:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
All of my aluminum block/head deals have grown between .014-.018"
Re: Aluminum motor growth [Re: an8sec70cuda] #2427760
01/02/18 03:08 PM
01/02/18 03:08 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Ditto.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Aluminum motor growth [Re: Efidart] #2427764
01/02/18 03:15 PM
01/02/18 03:15 PM
Charleston
Charleston
Thinking out loud here. So compression could actually be a 1/2 point lower when warmed up
Re: Aluminum motor growth [Re: sr440] #2427775
01/02/18 03:41 PM
01/02/18 03:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have expanded as I got older LOL
Re: Aluminum motor growth [Re: sixpackgut] #2427782
01/02/18 03:46 PM
01/02/18 03:46 PM
rowin4 Offline
rowin4  Offline
On a new build , aluminum block/ aluminum heads, what would be the best gap setting for initial startup ?
Re: Aluminum motor growth [Re: rowin4] #2427785
01/02/18 03:52 PM
01/02/18 03:52 PM
I would and have set them .012 tighter on a aluminum motor at room temps around 70F and then recheck the lash with the motor warmed up up scope
Adjust as needed wrench
Re: Aluminum motor growth [Re: sr4440] #2428058
01/03/18 12:01 AM
01/03/18 12:01 AM
NY
NY
Joe
Yes, everything expands. Steel is about 1/2 the rate of aluminum. I was only referring to the change in lash due to deck growth being about 0.017" with 1.7 rockers. There are other factors, some add lash, some reduce it. Ya gotta check it hot to know for sure where it'll end up.
Re: Aluminum motor growth [Re: sixpackgut] #2428060
01/03/18 12:03 AM
01/03/18 12:03 AM
Superfreak
Superfreak
Where and what are you measuring when checking for growth?
