Aluminum motor growth
#2426895
01/01/18 01:59 AM
01/01/18 01:59 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
If an iron block aluminum head growth is roughly .006 what might one expect out of an all aluminum engine?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Aluminum motor growth
[Re: sr440]
#2426986
01/01/18 11:13 AM
01/01/18 11:13 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
They don't grow Ray. They expand........ If they were to grow they would get old............ they do get old.i have al block and heads,just the valve lash grows from 8 thou to 20 thou.
[Re: challenger451ci]
#2427000
01/01/18 12:20 PM
01/01/18 12:20 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
My Indy Maxx with SR heads grows about 0.0.020" at temp. Indy told me the deck height would change about 0.010" at 170F. With a 1.7 rocker, that's ~0.017" lash change. That's about what we see...
[Re: sixpackgut]
#2427658
01/02/18 11:53 AM
01/02/18 11:53 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
My KB block/MP head hemi grows about .013" cold to hot. I lash the valves at .010" cold for .023" hot.
[Re: sixpackgut]
#2427690
01/02/18 12:58 PM
01/02/18 12:58 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
when I read " Indy told me the deck height would change about 0.010" at 170F. With a 1.7 rocker, that's ~0.017" lash change." My 1st thought is "doesn't your pushrods and valves expand also?" I know that the valves and the pushrods don't expand as much as the block (steel vs Al) but they do expand. Which is why if you run a iron block and iron head the clearance tightens up a few thousands. (iron vs steel)
Joe
Without Data, you’re just another guy with an opinion.
[Re: sixpackgut]
#2427748
01/02/18 02:54 PM
01/02/18 02:54 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
All of my aluminum block/head deals have grown between .014-.018"
[Re: an8sec70cuda]
#2427760
01/02/18 03:08 PM
01/02/18 03:08 PM
Posts: 200 AB
Efidart
AB
My KB block/MP head hemi grows about .013" cold to hot. I lash the valves at .010" cold for .023" hot. Ditto.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#2427764
01/02/18 03:15 PM
01/02/18 03:15 PM
sixpackgut
Charleston
Thinking out loud here. So compression could actually be a 1/2 point lower when warmed up
[Re: sr440]
#2427775
01/02/18 03:41 PM
01/02/18 03:41 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
They don't grow Ray. They expand........ If they were to grow they would get old............ I have expanded as I got older LOL
[Re: sixpackgut]
#2427782
01/02/18 03:46 PM
01/02/18 03:46 PM
rowin4
On a new build , aluminum block/ aluminum heads, what would be the best gap setting for initial startup ?
[Re: sr4440]
#2428058
01/03/18 12:01 AM
01/03/18 12:01 AM
Posts: 292 NY
challenger451ci
NY
Joe Yes, everything expands. Steel is about 1/2 the rate of aluminum. I was only referring to the change in lash due to deck growth being about 0.017" with 1.7 rockers. There are other factors, some add lash, some reduce it. Ya gotta check it hot to know for sure where it'll end up.
[Re: sixpackgut]
#2428060
01/03/18 12:03 AM
01/03/18 12:03 AM
Superfreak
Superfreak
Where and what are you measuring when checking for growth?
