Best source/ material to seal hood to carb pan?
#2425962
12/30/17 06:01 PM
12/30/17 06:01 PM
Posts: 4,693 Wichita
GY3
Wichita
Who has a good foam to do this? Should I do fireproof?
I already have he lower metal "pan" fabbed that fits the carb.
Re: Best source/ material to seal hood to carb pan?
[Re: GY3]
#2425977
12/30/17 06:19 PM
12/30/17 06:19 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When my Son worked at a scrap yard he bought some old road signs that were laying around. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Then I went to my local plumbing (hardware store) and bought 2 inch foam to seal it.
[Re: GY3]
#2425979
12/30/17 06:20 PM
12/30/17 06:20 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I already have he lower metal "pan" fabbed that fits the carb. My local store had 1/2 inch to 2 inch foam in stock.
[Re: GY3]
#2425990
12/30/17 07:03 PM
12/30/17 07:03 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I already have he lower metal "pan" fabbed that fits the carb. Lowe's or HD in the HVAC aisle, homie.
[Re: pittsburghracer]
#2426064
12/30/17 10:08 PM
12/30/17 10:08 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
I already have he lower metal "pan" fabbed that fits the carb. My local store had 1/2 inch to 2 inch foam in stock. Is that close cell or open cell foam? Which one is the best to use?
[Re: Cab_Burge]
#2426087
12/30/17 10:48 PM
12/30/17 10:48 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I already have he lower metal "pan" fabbed that fits the carb. My local store had 1/2 inch to 2 inch foam in stock. Is that close cell or open cell foam? Which one is the best to use? I used the black stuff to match the car when I have the hood off.
[Re: humpty]
#2426154
12/31/17 01:47 AM
12/31/17 01:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll be adding a tray and foam and doing it much like Humpty did but its gonna be on my Rampage EDIT Mine is a cowl set up so I need a pretty big tray to cover the whole cowl.. I think I will attach the tray right to the cowl to make it easy
