GOOD AFTERMARKET EVAPS #2425755
12/30/17 01:13 PM
12/30/17 01:13 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I need to replace the blower motor in our 97 Dakota, and yes, the evap is bad, and I'd like to replace it while they're in there. What's a good aftermarket replacement, if any.
Thanks.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: GOOD AFTERMARKET EVAPS [Re: Magnumguy] #2425796
12/30/17 02:16 PM
12/30/17 02:16 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Rock auto lists 3 aftermarkets brands all under $40. I dont have a recommendation. But an OEM is $114 from this supplier:
https://www.cdjrmoparparts.com/auto-part...or-and-fan-scat
https://www.rockauto.com/en/catalog/dodge,1997,dakota,5.2l+v8,1087714,heat+&+air+conditioning,blower+motor,6916
Keep old mopars alive.
Re: GOOD AFTERMARKET EVAPS [Re: Magnumguy] #2425831
12/30/17 02:54 PM
12/30/17 02:54 PM
S.E.Ohio
S.E.Ohio
Thanks 2 bolt main.
Re: GOOD AFTERMARKET EVAPS [Re: Magnumguy] #2425916
12/30/17 04:38 PM
12/30/17 04:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My honest opinion.
Buy an OEM . Or one of Mopars Value Line replacements.
Its a job I REALLY would rather not do a 2nd time because I went cheap
Re: GOOD AFTERMARKET EVAPS [Re: Magnumguy] #2426112
12/30/17 11:29 PM
12/30/17 11:29 PM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
When I did the one in my Durango, I spray painted it. I think that the aluminum developed pin holes from it sitting in water around the foam that held it in. Don't think it affected the performance of it, but I never did have real good heating or cooling in that vehicle.
