Bolt in Roll Bar ??? #2424987
12/28/17 05:41 PM
12/28/17 05:41 PM
TN
SCATPACK 1 Offline OP
TN
Hey Mike
Any thoughts on this?
I would like to keep my car street able to keep the wife happy for trips etc...
BUT, I would like to add a roll bar for the track. I Expect 10.50 1/4 mile times with the new motor.
Is it acceptable to use a roll bar that can be unbolted and removed for car shows and trips. No way my grand kids could get in the back seat with a roll bar cross bar in the way.
Old Geezer Racing
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2424991
12/28/17 06:06 PM
12/28/17 06:06 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
6 x 6 plates, top and bottom, can be used to attach the bar to the floor with bolts in all locations. The bar itself is required to be fully welded (crossbar, rear braces, etc.) except for swing out side bars. I've done bolt in cross bars for folks, but they were told up front that it will not pass tech.
That being said, done properly, it's a lot better than nothing and it becomes an issue between you and the tech guy at your local track. I've been told that roll bar padding hides things like this from tech guys who are just glancing in the car.
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2425034
12/28/17 07:54 PM
12/28/17 07:54 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's how we did my rear seat bar. It's a street car that will only see a couple track days per year. And yes the roll bar padding can hide it.
Re: Bolt in Roll Bar ??? [Re: ProSport] #2425045
12/28/17 08:23 PM
12/28/17 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I hate them BUT to make the wife happy you have
to do what you have to.. as said already.. add
the extra plates.. if you want.. make them
a through bolt set up.. that way you can pull
the bar(un-bolt) and put plastic plugs in the
floor to keep it dry(with silicone on them)... I
put one bolt in bar in my life(was for my brother
way back when).. he later asked for a weld in one
wave
Re: Bolt in Roll Bar ??? [Re: MR_P_BODY] #2425377
12/29/17 03:09 PM
12/29/17 03:09 PM
TN
TN
OK Thanks for the info guys.
That is about what I thought I would be dealing with.
Old Geezer Racing
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2425957
12/30/17 05:50 PM
12/30/17 05:50 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I had the same deal going on.... wife didn’t want a bar in the car, thought it would ruin the car. I always want buy-in from my wife on everything I do, so it doesn’t become divisive. But I refuse to spend money on something that is not NHRA legal. I always thought: who knows when you’ll be at the track all geeked up for a fun day, only to be told “sorry, you’re not making passes with this, and don’t come back until it’s fixed”. So I walked the pits with her one day last year and showed her some nice cars with nice tucked away bar setups. She realized it wasn’t going to “ruin” the car, so I’m in the process of installing a custom bent bar in the Satellite right now. The back seat thing does become an issue though.
Good luck and hope you’re happy with the results.
wave
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2425983
12/30/17 06:31 PM
12/30/17 06:31 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The roll bar in my Demon is bolted in. I've never had a problem passing tech in any way.
Nautilus Racing-
Re: Bolt in Roll Bar ??? [Re: Chris2581] #2426037
12/30/17 09:02 PM
12/30/17 09:02 PM
Puyallup, WA
Puyallup, WA
If I’m not mistaken, It’s not the bolt in bar part tech would have issue with, it’s the removable mid-bar that would get the conversation going with an NHRA guy.
Re: Bolt in Roll Bar ??? [Re: StealthWedge67] #2426273
12/31/17 12:55 PM
12/31/17 12:55 PM
moparx Offline
moparx  Offline
as suggested before, have the bar upholstered to match, just leaving the weld to the main hoop exposed so the inspector can easily see the weld and nothing more.
beer
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2426294
12/31/17 01:46 PM
12/31/17 01:46 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I always thought if i wanted a removable bar I'd use something like a camburg interlocking tube clamp.
Re: Bolt in Roll Bar ??? [Re: SCATPACK 1] #2426848
01/01/18 12:00 AM
01/01/18 12:00 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Bolt in roll bar is very popular with the import cars. So you have this German/Japan racer that rally's, drifts and now wants to drag race. They always pass through tech unless they are running in the low 9's or quicker. Tech likes a plate inside and under the body sheet metal. Its getting iffy at the track with factory cars dipping into the low 10's in factory condition.
