Repairing Shaker trim ring studs? #242488
03/03/09 10:34 PM
03/03/09 10:34 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Question on best way to repair shaker hood trim ring studs that are broken off.
First though was to grind off the pot metal remnants and tig weld a flat head 10-24 screw to the ring but wondering if anyone has been successful at tig welding to the pot metal original shaker trim ring. I know that some pot metal is not conducive to tig welding.
Other option I know of is drill, tap and install a stud.
Only two are broken and hate to buy a repro.
Any suggestions?
Thanks!!!
Re: Repairing Shaker trim ring studs? [Re: sawdust] #242489
03/03/09 10:36 PM
03/03/09 10:36 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Contact member mccannix
Re: Repairing Shaker trim ring studs? [Re: sawdust] #242490
03/03/09 10:47 PM
03/03/09 10:47 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Jeff Bobst 319-352-2511
Re: Repairing Shaker trim ring studs? [Re: FY1TA] #242491
03/05/09 07:52 AM
03/05/09 07:52 AM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
I ground down the broken studs, placed the ring on hood, marked center of holes that needed repaired. Drilled, tapped and ran a new stud through the top and set it with JB Weld. Cut off top of bolt that was on the top side of ring, Very small amount of spot putty, worked out very well.
Re: Repairing Shaker trim ring studs? [Re: N9671X2] #242492
03/05/09 08:32 AM
03/05/09 08:32 AM
Mopar World Headquarters
P1970HeMICuDA Offline
I agree, I ground the stud down on the top, then filled small divet with All-Metal body filler. That stuff can be filed or sanded.
Re: Repairing Shaker trim ring studs? [Re: P1970HeMICuDA] #242493
03/07/09 08:19 AM
03/07/09 08:19 AM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Thanks, that was the one approach I was leaning towards. Will try this weekend, as getting ready to shoot the body this month.
Re: Repairing Shaker trim ring studs? [Re: sawdust] #242494
03/07/09 09:13 AM
03/07/09 09:13 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My late cousin ground the head of the correct size bolts down until it was slightly thinner than a dime. He then used high quality epoxy to glue the modified bolt to the trim ring. It was amazingly strong and long lasting. In fact, they seemed stronger than the originals and are still in place today.
