Re: Repairing Shaker trim ring studs?
[Re: N9671X2]
#242492
03/05/09 08:32 AM
03/05/09 08:32 AM
Posts: 943 Mopar World Headquarters
P1970HeMICuDA
I ground down the broken studs, placed the ring on hood, marked center of holes that needed repaired. Drilled, tapped and ran a new stud through the top and set it with JB Weld. Cut off top of bolt that was on the top side of ring, Very small amount of spot putty, worked out very well.
I agree, I ground the stud down on the top, then filled small divet with All-Metal body filler. That stuff can be filed or sanded.
[Re: sawdust]
#242494
03/07/09 09:13 AM
03/07/09 09:13 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
My late cousin ground the head of the correct size bolts down until it was slightly thinner than a dime. He then used high quality epoxy to glue the modified bolt to the trim ring. It was amazingly strong and long lasting. In fact, they seemed stronger than the originals and are still in place today.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
