Magnum Head Valve Springs #2424613
12/27/17 09:09 PM
12/27/17 09:09 PM
B.C. Canada
hankcrank Offline OP
B.C. Canada
Is there an upgrade valve spring for these heads that use the stock retainers and locks and require no machining"
All the posts I can find on the subject are "maybe" "should" or "try"If someone actually has made this upgrade the brand and part number would be appreciated.
Thanks and have a Happy New Year
Re: Magnum Head Valve Springs [Re: hankcrank] #2424622
12/27/17 09:33 PM
12/27/17 09:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have built a mess of them there magnums and never come across any upgrade spring using the stock retainers. The closest thing I have found for a cheap simple upgrade is the GM 3100 springs and retainers, they give just a little more pressure with a little lighter retainer for a nice overall upgrade that will work with mild cam upgrades. I have also shimmed the stock springs for very mild upgrades or just when I want to turn a stock cam higher RPM because I got rid of the beer barrel intake for something more performance oriented, they tend to be happy turning another 500 RPM with any better intake.
Re: Magnum Head Valve Springs [Re: hankcrank] #2424624
12/27/17 09:34 PM
12/27/17 09:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Google............
LA confidential mopar
That article is about an enginemasters 318 magnum build. Lists part numbers, etc, etc.
Might help ya out with ideas
I bought the motor, ran superbly.......to 6500 rpm
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Magnum Head Valve Springs [Re: hankcrank] #2424691
12/27/17 11:49 PM
12/27/17 11:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.hughesengines.com/Index/produ...mp;partid=30450
kit includes springs..retainer and locks...say no machining needed .550 lift coil bind @ .620.
Not sure about top of guide clearance.
Tony
70 AARCuda Vitamin C
