small block headers question
#2423909
12/26/17 02:39 PM
12/26/17 02:39 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
If you guys had to choose between Tubular Automotive and TTI 1-7/8 headers for a street car that ill take to the track every once in a while, what rout would ya go?
Used ceramic coated Tubular auto slip tube headers in really good shape, but Ill have to run adapters,
Bite the bullet and go with 1 7/8 TTI headers???
difference is around 480 bucks if I go the TTI way
Asking because Ive had bad luck in the past with adapters.
Also know nothing about the Tubular auto stuff. I did call the company and they are really cool and gave me good info, but I didn't ask him how his compare to TTI that's not a fair question to ask a guy abut a competitor.
Kasey
Re: small block headers question
[Re: Moparnut426]
#2423926
12/26/17 03:21 PM
12/26/17 03:21 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Had a buddy who had the tubular auto 1 7/8 headers on a 408 in a 72 Demon. They didnt fit too bad. If its the ones i am thinking, one tube on the driver side slid out( slip fit)
[Re: Moparnut426]
#2423944
12/26/17 04:31 PM
12/26/17 04:31 PM
Posts: 4,989 new jersey usa
11secdart
new jersey usa
I have ran Tubular Automotive headers for years, bought a used set, a new set years ago and am getting ready to buy a new set. I was thinking about the TTIs but heard fit isn't the greatest and they are just to expensive. With the Tubular Automotive headers I have plates for W2 heads and regular heads like an X or J head etc. Mine are 1 7/8 with a 3 1/2 collector
[Re: Moparnut426]
#2423957
12/26/17 05:09 PM
12/26/17 05:09 PM
B3422W5
Portage,michigan
Hey guys, anybody note how high up the collectors are underneath on the TA ones. Is there good ground clearance.
[Re: B3422W5]
#2423961
12/26/17 05:17 PM
12/26/17 05:17 PM
11secdart
new jersey usa
Yes mine have the tabs to bolt the tubes together, mine are just plain worn out from being apart so many times for engine swaps etc.
[Re: 6bblRoadrunner]
#2424026
12/26/17 06:51 PM
12/26/17 06:51 PM
B3422W5
Portage,michigan
B3442W5... I’m out of town right now so I can’t give you any measurements. I’ll be back the end of the week and will post then. Cool. Just want to be able to hook bullets up to them and keep them tight to the undercarriage.
[Re: B3422W5]
#2424036
12/26/17 07:19 PM
12/26/17 07:19 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why no love for the 1 7/8 Hedmen headers?
[Re: pittsburghracer]
#2424044
12/26/17 07:33 PM
12/26/17 07:33 PM
Posts: 4,457 Washington
madscientist
Washington
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes.
[Re: madscientist]
#2424060
12/26/17 08:00 PM
12/26/17 08:00 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes. I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL
[Re: Moparnut426]
#2424065
12/26/17 08:02 PM
12/26/17 08:02 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I can't do a comparison on the headers but I do know my stepped TTI Headers fit my car with no problems. Mine have the slip on pipe for for number 7 Cyl but I have never needed to take it off during standard engine and transmission services. They slide right in from the bottom and bolt right up. If and when my wear out I will get the exact same headers again. My 2cents
6.50 @105.26
#2424070
12/26/17 08:12 PM
12/26/17 08:12 PM
Moparnut426
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes. I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL My Supercomps are for a full bodied car that fit with tortion bars, not a fender well header
[Re: Moparnut426]
#2424074
12/26/17 08:17 PM
12/26/17 08:17 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
I have TTI 1 7/8 with W2s in an A body. They fit great, tight but great. They mention in the instructions that you need to jack the car up to install. What they do not mention is that you have to jack the car up really really really high lol.
68 Barracuda Formula S 340
