727 Thick Lug Pump Gears #2423363
12/25/17 12:22 AM
12/25/17 12:22 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
At what point should these be considered?
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423365
12/25/17 12:36 AM
12/25/17 12:36 AM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
I learned the hard way. Do not just let your foot off the gas as soon as you go through the traps. I told the trans builder my story, to which he replied " most of them let go on sudden decel" I can't give you a HP #, but I can tell you driving style can help or hurt. My 2¢ merry Christmas!
Woodruff Carburetor Specialties
330-799-9479
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423368
12/25/17 12:43 AM
12/25/17 12:43 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Also, whenever they need replacing, as the oem are discontinued, and the aftermarket ones are all over the place on tolerance.
Re: 727 Thick Lug Pump Gears [Re: Vincenzo] #2423373
12/25/17 12:59 AM
12/25/17 12:59 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Do high line pressures play a role?
Re: 727 Thick Lug Pump Gears [Re: Leigh] #2423374
12/25/17 01:01 AM
12/25/17 01:01 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Which tolerances Leigh? Are they correctable?
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423380
12/25/17 01:10 AM
12/25/17 01:10 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
End play, tip to tip and outer bore. None are correctable.
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423394
12/25/17 01:35 AM
12/25/17 01:35 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can turn your converter back & forth and feel the the play where the snout goes into the pump.When I upgraded the drum I also bought the max lug pump gears.The lug is wider and fits tight into the snout.
http://www.tcsproducts.com/products/product/tf727-max-lug-pump-gear-set/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423428
12/25/17 03:54 AM
12/25/17 03:54 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Easier to put one in now then pull it out to put one in later .
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423465
12/25/17 09:50 AM
12/25/17 09:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
as with many.... I upgraded when I broke a set, and last year I had my 727 out many times with weird breakage. Pro Trans was out so I ended up getting a set from TCS and had them fitted to my pump case. Knock on wood things have been holding up. It's been in my mind that changing to a clean N trans brake might have played a role in this.
Re: 727 Thick Lug Pump Gears [Re: Hot 340] #2423551
12/25/17 01:46 PM
12/25/17 01:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've never broke a set. Nor have I taken one apart with a broken set. Lucky? Can't say but I've built a ton of them. Currently running 2 cars with 850hp+ on stock parts, one has 500 passes.
Doug
