Spray bar valve covers #2416848
12/11/17 05:29 PM
12/11/17 05:29 PM
Kentucky
3
301v Offline OP
301v  Offline OP
Kentucky
1st question would be do you like spray bar valve covers or pushrod oiling and why?
And also those with spray bar covers where are you putting the fitting for the vacuum pump in the valve cover?
Re: Spray bar valve covers [Re: 301v] #2416858
12/11/17 05:37 PM
12/11/17 05:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The typical Indy spray bar valve cover has the tube located right up against the inboard side of the V/C, and they spray straight down onto the rockers, so you can still put the vac pump fitting pretty much anywhere you like.
If you can get lifters that won't allow the top end to be over oiled, then my preference would be to pushrod oil.
This assumes you'll be running rockers that are pushrod oiling compatible.
That being said, I have several customers running Jesel rockers with the spray bar oiling, and none of them has ever had any issues with that system.
Re: Spray bar valve covers [Re: 301v] #2416864
12/11/17 05:48 PM
12/11/17 05:48 PM
AndyF Offline
AndyF  Offline
I had issues burning pushrods with the Indy spray bar valve covers so I switched to pushrod oiling. I left the spray bars so I oil both ways. I might turn off the spray bar oiling at some point to see if I still need it.
My recommendation is to use pushrod oiling if you can. If you can't then the spray bar might work for you. As Dwayne says, some folks use the spry bar oiling without any issues so evidently it can be sorted out and made to work.
Re: Spray bar valve covers [Re: AndyF] #2416978
12/11/17 09:05 PM
12/11/17 09:05 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I have run spray Bar Oiling on both of my big motors. Both with .800" cams. Never any problems with wear and both are street cars. I think that setup helps cool the valve springs, which is good on a street car.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Spray bar valve covers [Re: Old School] #2417361
12/12/17 02:42 PM
12/12/17 02:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What spring pressure and lifters are you using for .800 lift to live in the street??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spray bar valve covers [Re: hemi-itis] #2417423
12/12/17 04:26 PM
12/12/17 04:26 PM
My next bracket motor, 400 block, 4.300 stroke, Indy CNC ported 440-1 heads with Jesel paired rockers has both pushrod oiling and spray bars,no restrictors except what is in the covers with the fittings they come with.
These Jesel rocker arms come with hollow adjusters with no provisions for pressure oiling the shafts, roller tips or any thing else shock
I called Jesel about this and they insist that splash oiling from the pushrods is more then enough to oil this system confused luck
I haven't ran this motor yet, I'll post more about it after I put it on the dyno or in the car luck
Re: Spray bar valve covers [Re: hemi-itis] #2417730
12/13/17 01:22 AM
12/13/17 01:22 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I use Iskys bushed E-Z roll max lifters. They are the only lifters that have ever lasted on the street for me. Needle bearing lifters always failed on me.
Springs are PAC 1224. 275# @ 2" approx 850#@ full lift. I change them out every couple years......
Re: Spray bar valve covers [Re: 301v] #2421835
12/21/17 01:27 PM
12/21/17 01:27 PM
WI
N
nippy1969 Offline
nippy1969  Offline
N
WI
I don't mean to hijack the post, but I was just about to list a brand new pair of spray bar valve covers INDY 440-V2-8S on eBay. Anybody interested before I list them? $449 from Mancini, I'll sell these for $375. I bought them new from Indy for a project that never materialized.
Call or text me if your interested
Mike 262-227-4984
