Engine, straight or angled
#241265
03/02/09 08:45 PM
03/02/09 08:45 PM
Posts: 51 Martinez, California
Challenged
Hello to all, I installed a Control Freak IFS in my 72 Challenger. When installing the engine using the brackets and isolators sent with the IFS I found that the engine was at an angle front to rear . I noticed this right away as the sixpack on top made it obvious. If you were to run a string from the center of the engine in the front through the center of it to the rear of the car the string would be toward the left/drivers side. I talked to a guy who has done plenty of mopar engeine installs and was told this is common and that the tranny tunnel is also at an angle . I could swear that when my previous engine was in the car it was sitting in a straght line front to rear . Can anybody verify this. Thanks for your .
Re: Engine, straight or angled
[Re: babarracuda]
#241267
03/02/09 08:56 PM
03/02/09 08:56 PM
Posts: 10,717 North Dakota
6PakBee
North Dakota
Sounds like the typical offset to the right.
[Re: 6PakBee]
#241269
03/02/09 09:15 PM
03/02/09 09:15 PM
Challenger 1
Cincinnati, Ohio
Naw it sounds like he said at a angle? Tranny tunnel is not angled as some have suggested.
[Re: Challenged]
#241270
03/02/09 09:16 PM
03/02/09 09:16 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Sounds like pretty much every RWD Chrysler product Ive ever seen. They are all offset to the passenger side
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#241271
03/03/09 04:27 AM
03/03/09 04:27 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you don't mean the engine is tipped over towards one side do you? as in, the top of the engine is closer to the left side than the bottom of the engine, right? you're just talking about how much space is between the block and driver side inner fender vs how much space is between the block and the passenger side fender, right? if so, that's normal.
**Photobucket sucks**
[Re: Challenged]
#241273
03/03/09 02:08 PM
03/03/09 02:08 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
We all know the engine/transmission offset towards the passenger side to be correct, but what you are describing is in no way correct. The crank centerline should be parallel with the centerline of the car.
This is why I bought an AlterKtion, no worries with geometry at all...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: Challenged]
#241279
03/03/09 06:38 PM
03/03/09 06:38 PM
Posts: 6,516 Santa Cruz, California
Lefty
As for my choice of Control Freak over Alterktion you may be right, will have to wait and see.
We need updates I've been wondering how well they work.
