Hello to all, I installed a Control Freak IFS in my 72 Challenger. When installing the engine using the brackets and isolators sent with the IFS I found that the engine was at an angle front to rear
. I noticed this right away as the sixpack on top made it obvious. If you were to run a string from the center of the engine in the front through the center of it to the rear of the car the string would be toward the left/drivers side. I talked to a guy who has done plenty of mopar engeine installs and was told this is common and that the tranny tunnel is also at an angle
. I could swear that when my previous engine was in the car it was sitting in a straght line front to rear
. Can anybody verify this. Thanks for your
