change a white stripe F70-14 to red? what to use? #2406989
11/21/17 07:59 PM
11/21/17 07:59 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
wanting to put a F70-14 in the trunk of a '69 Road Runner
what has anyone used to change a white stripe to red? SHARPIE?
Re: change a white stripe F70-14 to red? what to use? [Re: 6bblgt] #2407041
11/21/17 09:47 PM
11/21/17 09:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't think a sharpie would work, though it would be inexpensive to find out. I would think a flat red paint would work if it's just a spare. Chuck the wheel & tire on a front spindle, use a hand rest, and spin it while you stripe. Wipe any excess off with lacquer thinner.
Re: change a white stripe F70-14 to red? what to use? [Re: topside] #2407190
11/22/17 02:02 AM
11/22/17 02:02 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think you'd get streaks using a marker.
Maybe some sort of red dye on a sponge while the wheel is being spun as suggested above? Likely to be pink at first so you may need to go over it a couple times to hit the right shade.
Re: change a white stripe F70-14 to red? what to use? [Re: 6bblgt] #2407218
11/22/17 04:20 AM
11/22/17 04:20 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Tried many until I found the red Marks-A-Lot brand permanent marker. Hard to get a good color comparison in the photos I took at the time but I had a few original red lines as I was comparing the Marks-A-Lot red marker to them (and other markers and even paint) In natural outside light it's, IMO, spot on and no streaks. I think I went around a total of three overlapping times across the width of the tire "line" or streak.
MikeR
(note: the valve stem is centered in the GOOD#YEAR, pretty an@l eh? blush)
Re: change a white stripe F70-14 to red? what to use? [Re: 6bblgt] #2407299
11/22/17 12:07 PM
11/22/17 12:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
MikeR
iagree
I did a customers 67 GTX white wall tires the same way, he was thrilled with the results, and since I had the pens on hand, especially happy with the cost of zero dollars smile
Re: change a white stripe F70-14 to red? what to use? [Re: ScottSmith_Harms] #2407359
11/22/17 02:11 PM
11/22/17 02:11 PM
New York
rarefish Offline
rarefish  Offline
New York
About 10 years ago I bought a red tire marker from Summit Racing with the idea of turning these F-70 Goodyear Speedways into a set of red line tires.
It turned out to be a waste of money. The markers were junk. I think they were made by Dupli-color.
Re: change a white stripe F70-14 to red? what to use? [Re: 6bblgt] #2407397
11/22/17 03:49 PM
11/22/17 03:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I need the white strip for my car, where did you purchase them? Thanks
Mike
Re: change a white stripe F70-14 to red? what to use? [Re: cudaman1969] #2407471
11/22/17 05:41 PM
11/22/17 05:41 PM
New York
rarefish Offline
rarefish  Offline
New York
Those white walls are vintage Speedway tires that were made around 1970. I found them on Craigslist around 2008. They were still nearly like new.
I mounted them on my original 14" Charger steel wheels and then installed the original wheel covers that the car was ordered with.
I like the look, but driving on them is a real experience. It's kind of like steering a roller skate.
Re: change a white stripe F70-14 to red? what to use? [Re: rarefish] #2407566
11/22/17 09:11 PM
11/22/17 09:11 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks for the info, by the way, my favorite year Charger, very nice. I actually need E70 14 white lines, red was standard but they ordered the white. Should look good car being all black. Thanks again.
Re: change a white stripe F70-14 to red? what to use? [Re: 6bblgt] #2407611
11/22/17 11:22 PM
11/22/17 11:22 PM
New York
rarefish Offline
rarefish  Offline
New York
Re: change a white stripe F70-14 to red? what to use? [Re: rarefish] #2407617
11/22/17 11:29 PM
11/22/17 11:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Best bang for the buck for white to red:
Re: change a white stripe F70-14 to red? what to use? [Re: A12] #2410505
11/29/17 01:56 AM
11/29/17 01:56 AM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
Snarl softly and carry a BIG stick 1969 Hurst/Olds Pure Stock 13.23@ 103.1 and the a/c blows cold! Rusty Small
Re: change a white stripe F70-14 to red? what to use? [Re: cudaman1969] #2410507
11/29/17 01:58 AM
11/29/17 01:58 AM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
Mike
Give me a call!! 816-654-3400
