Holley fuel bowl question
#2405317
11/18/17 03:36 AM
11/18/17 03:36 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
With a couple carefully drilled holes, can a secondary fuel bowl from a vac secondary Holley 3310 be converted to be used on a 4779 DP? In other words, can you convert a non-accelerator pump fuel bowl to utilize an accelerator pump?
I need a bowl for my old 4779 and have a couple from old 3310's, with associated parts. It looks like the castings have the provisions for the old check ball valves and hold down tabs, but without the holes drilled for the fuel to pass through and threads for the pump diaphragm cover. I have extra check balls hold down tabs, extra pump diaphragm covers, etc. I'm wondering if a drilling a couple holes and tapping the pump cover screw holes can make the pump functional.
Has anyone done this before?
Re: Holley fuel bowl question
[Re: Dave Hall]
#2405323
11/18/17 04:03 AM
11/18/17 04:03 AM
mopowers
Sac, CA
Try it! Standard Holley bowls are relatively cheap. Sounds like you want a DP anyway? I'm sure the bowl, if you had another one to model for the passages and such, would work fine. The linkage may be another story that I'm not familiar with... I've already got the 4779 DP. Unfortunately, the secondary fuel bowl has stripped needle and seat threads. I have a couple 3310 sec bowls and comparing the two, appears as if they're the same castings, but missing the fuel passages associated with the accelerator pump, and threads for the diaphragm cover of course. I'm definitely going to try it, since I have the pieces. Just wondering if anyone has done this before?
[Re: Dr Dave]
#2405449
11/18/17 02:39 PM
11/18/17 02:39 PM
mopowers
Sac, CA
Thinking, couldn't you repair it with a Heli coil? I could if I could find a 3/8-32 helecoil. Plus, the kit would likely cost as much as a new bowl. New bowls are only about $45. If this doesn't work, that'll be the route I go. Thanks
[Re: mopowers]
#2405453
11/18/17 02:50 PM
11/18/17 02:50 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
If not in a great hurry look around for a complete used carb that has the bowl you want and then you can get extra parts for a Double Pumper.
1971 HEMI E BODY REGISTRY
[Re: mopowers]
#2405472
11/18/17 03:19 PM
11/18/17 03:19 PM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
Check out your local car parts swaps. I usually found carbs for the 5-15 dollar range for parts. Is yours stripped out where the needle and seat threads into? If so, the cause is using a non Holley needle and seat which uses a big brass nut to lock things down. You get these in parts store aftermarket carb kits. The thread pitch is off 1-2 threads from the correct one and will strip out the bowls. Gots to use oe Holley or one of the better companies like Quik Fuel etc to get correct stuff.
Carl Kessel
[Re: Dr Dave]
#2405510
11/18/17 04:45 PM
11/18/17 04:45 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thinking, couldn't you repair it with a Heli coil? Helicoil won't last,this is the only permanent fix !!
[Re: 62maxwgn]
#2405602
11/18/17 07:48 PM
11/18/17 07:48 PM
mopowers
Sac, CA
Thinking, couldn't you repair it with a Heli coil? Helicoil won't last,this is the only permanent fix !! What is that? Where do you get them?
[Re: mopowers]
#2405610
11/18/17 07:55 PM
11/18/17 07:55 PM
62maxwgn
Blair County,PA
Thinking, couldn't you repair it with a Heli coil? Helicoil won't last,this is the only permanent fix !! What is that? Where do you get them? That is a brass or aluminum insert I do myself.
[Re: Supercuda]
#2405769
11/19/17 01:45 AM
11/19/17 01:45 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
If it doesn't work just get some new Quick Fuel bowls from Summit or if you are strapped for cash send me a PM and I could send you a bowl I have in my collection of junk. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
