Holley fuel bowl question #2405317
11/18/17 03:36 AM
11/18/17 03:36 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
With a couple carefully drilled holes, can a secondary fuel bowl from a vac secondary Holley 3310 be converted to be used on a 4779 DP? In other words, can you convert a non-accelerator pump fuel bowl to utilize an accelerator pump?
I need a bowl for my old 4779 and have a couple from old 3310's, with associated parts. It looks like the castings have the provisions for the old check ball valves and hold down tabs, but without the holes drilled for the fuel to pass through and threads for the pump diaphragm cover. I have extra check balls hold down tabs, extra pump diaphragm covers, etc. I'm wondering if a drilling a couple holes and tapping the pump cover screw holes can make the pump functional.
Has anyone done this before?
Re: Holley fuel bowl question [Re: mopowers] #2405319
11/18/17 03:52 AM
11/18/17 03:52 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Try it! Standard Holley bowls are relatively cheap. Sounds like you want a DP anyway? I'm sure the bowl, if you had another one to model for the passages and such, would work fine. The linkage may be another story that I'm not familiar with...
Re: Holley fuel bowl question [Re: Dave Hall] #2405323
11/18/17 04:03 AM
11/18/17 04:03 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I've already got the 4779 DP. Unfortunately, the secondary fuel bowl has stripped needle and seat threads. I have a couple 3310 sec bowls and comparing the two, appears as if they're the same castings, but missing the fuel passages associated with the accelerator pump, and threads for the diaphragm cover of course.
I'm definitely going to try it, since I have the pieces. Just wondering if anyone has done this before?
Re: Holley fuel bowl question [Re: mopowers] #2405436
11/18/17 02:01 PM
11/18/17 02:01 PM
Dr Dave Offline
Dr Dave  Offline
Thinking, couldn't you repair it with a Heli coil?
Re: Holley fuel bowl question [Re: Dr Dave] #2405449
11/18/17 02:39 PM
11/18/17 02:39 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I could if I could find a 3/8-32 helecoil. Plus, the kit would likely cost as much as a new bowl. New bowls are only about $45. If this doesn't work, that'll be the route I go.
Re: Holley fuel bowl question [Re: mopowers] #2405453
11/18/17 02:50 PM
11/18/17 02:50 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
If not in a great hurry look around for a complete used carb that has the bowl you want and then you can get extra parts for a Double Pumper.
1971 HEMI E BODY REGISTRY
Re: Holley fuel bowl question [Re: mopowers] #2405472
11/18/17 03:19 PM
11/18/17 03:19 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Check out your local car parts swaps. I usually found carbs for the 5-15 dollar range for parts. Is yours stripped out where the needle and seat threads into? If so, the cause is using a non Holley needle and seat which uses a big brass nut to lock things down. You get these in parts store aftermarket carb kits. The thread pitch is off 1-2 threads from the correct one and will strip out the bowls. Gots to use oe Holley or one of the better companies like Quik Fuel etc to get correct stuff.
Carl Kessel
Re: Holley fuel bowl question [Re: Dr Dave] #2405510
11/18/17 04:45 PM
11/18/17 04:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Helicoil won't last,this is the only permanent fix !!
Re: Holley fuel bowl question [Re: 62maxwgn] #2405602
11/18/17 07:48 PM
11/18/17 07:48 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What is that? Where do you get them?
Re: Holley fuel bowl question [Re: mopowers] #2405610
11/18/17 07:55 PM
11/18/17 07:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That is a brass or aluminum insert I do myself.
Re: Holley fuel bowl question [Re: mopowers] #2405613
11/18/17 07:59 PM
11/18/17 07:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Holley fuel bowl question [Re: Supercuda] #2405769
11/19/17 01:45 AM
11/19/17 01:45 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If it doesn't work just get some new Quick Fuel bowls from Summit or if you are strapped for cash send me a PM and I could send you a bowl I have in my collection of junk.
Gus beer
64 Plymouth Savoy
Dana 60
