Accelerator pump nozzle question #2404550
11/16/17 05:38 PM
11/16/17 05:38 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
This Winter is going to kill me. I just put new heads and intake on the car. I beat feet to get it done and go to the track before the end of the year but, the track closed early so; I’ll have to wait until Spring. I keep thinking about things and probably will all Winter until I can make it to the track (my sickness just keeps getting worse as I get older).
Anyway, with the swap, the motor wants more fuel and I got my off idle flat spot back. When I first got the motor down in the car years ago, I had to mess with the carb (850 Street HP) to get the off idle lean bog to go away. This bog was confirmed on a chassis dyno; the afr would spike to 17 or so and then come back down to where it should be. It ended up taking 40 pump squirters front and back and a 50cc diaphragm up front to cure the bog. Now, before I ran out of time, I ended up with 47’s both front and back and changed the back diaphragm to a 50cc and the flat spot was close to being gone but, not all the way.
Next spring, I want to mess with the cams as I know 50cc diaphragms should be used with the brown and yellow cams (maybe one other one too if I can remember right) which are not currently on the car right now.
My question is, does this sound like too much squirter to you? Is there some other adjustment I can mess with to get the squirter size down? I just feel like I’m missing something.
FYI, the timing is at 18 initial and 38 total (I’ll probably knock the total down to 36), my idle adjustment screws are at about ¾ of the way out (I set the screws using a vacuum gauge) and my transfer slot exposure is correct.
Mild 470 low deck with ported 906’s, an Edlebrock DP4b, comp xe hydraulic flat tappet (if I can remember right, its 230/236 at 50); nothing too wild.
Re: Accelerator pump nozzle question [Re: parksr5] #2404553
11/16/17 05:48 PM
11/16/17 05:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That much squirter is compensating for a horrible idle/transition condition..........I can fix you up if needed and have done several for people on here and rarely need more than a .035 on anything gas........... thumbs
Re: Accelerator pump nozzle question [Re: parksr5] #2404556
11/16/17 05:56 PM
11/16/17 05:56 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
Hey, right off the bat, the guy I was trying to attract to the thread answered. The thought crossed my mind to send it out to you. I'm not a carb magician by any stretch of the imagination but, I do enjoy leaning things so; I've messed with the carb myself, read up and ext.
I may send you a pm in the coming weeks to discuss this further.
Thanks!
Re: Accelerator pump nozzle question [Re: parksr5] #2404562
11/16/17 06:11 PM
11/16/17 06:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No problem or I can walk ya through a few things if you're willing to drill n tap some stuff.......... beer
Re: Accelerator pump nozzle question [Re: parksr5] #2405068
11/17/17 04:57 PM
11/17/17 04:57 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I'm no carb expert by no means. I get by with trial and error, mostly the latter!!!!My friend has the same carb with the same problem. He has a small block stroker. I ended up with .036" IFR's with stock jetting, 35 squirters up front and 37 out back. 50 cc pump on the secondaries with brown cam. Timing was at 36, if I recall, mostly all out just off idle. Hope this points you in the right direction
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Accelerator pump nozzle question [Re: 68LAR] #2405078
11/17/17 05:21 PM
11/17/17 05:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
In some cases the bigger ifrs/idle bleed combos help as you found out and lately I've been putting in bigger ifr's to help out the idle/transition circuits and to come up on the boosters happier instead of a big lean dip. However, this apply's to some and others may need to be leaner for various reasons but the wide band and plug reading go a long way here and a chassis dyno better yet........ beer
Re: Accelerator pump nozzle question [Re: Thumperdart] #2405084
11/17/17 05:35 PM
11/17/17 05:35 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
When you add bigger ifrs, what does it do to the idle fuel screws; do you normally have to turn them in some more?
Re: Accelerator pump nozzle question [Re: parksr5] #2405176
11/17/17 08:57 PM
11/17/17 08:57 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
In all my cases,(going lean off idle), the idle mixture screws didn't need adjusted much, if at all. The idle mixture screws can help very little with off idle boggs. They actually control the volume of air/fuel mixture being delivered at idle to the small holes below the throttle blades. The IFR's affect fuel to transition slots. If I'm wrong with this description, I'm sure someone will jump in and correct me.....
Re: Accelerator pump nozzle question [Re: 68LAR] #2405278
11/18/17 01:46 AM
11/18/17 01:46 AM
I have found working on the idle air bleeds affect the AFR from idle to WOT, not sure about the idle fuel feed restriction channels on how they affect the AFR at WOT shruggy confused
I did see a measureable difference in the AFR readings by leaning them down at idle and part throttle cruise also, CRS on WOT whiney
Re: Accelerator pump nozzle question [Re: parksr5] #2405289
11/18/17 02:08 AM
11/18/17 02:08 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
For me if the mixture screws have to be turned too far in say 1/2 turn from seated then I size down the ifr's and if they need to be like 2 turns out then bigger ifr's as a starting point. I size the idle bleeds according to the ifr's and go from there seeing/feeling the differences good and bad. I find the mixture screws play a HUGE role in how rich/lean the idle, transfer and cruise is on my Dart and there's a big difference between 1 3/4 turns out and 2 turns once it has heat in it. Same w/leaner mixtures, my car recovers faster when the happy peddle is mashed being in the 12-13 afr range while leaving a stop light and cruising instead of the 14-15's........... thumbs
Re: Accelerator pump nozzle question [Re: parksr5] #2405303
11/18/17 02:37 AM
11/18/17 02:37 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Ok. Question. Why are the 50cc pumps going on the secondary bowl? These DP's don't open the secondary circuit until after the off idle transition. Had the same problem on my Frankenstein Dart and 50cc on the primary solved it. My carb is too small and I had to screw in some smaller bleeds up top as well. Not perfect by any means but NO off idle, lean stumble.
Re: Accelerator pump nozzle question [Re: parksr5] #2405398
11/18/17 12:38 PM
11/18/17 12:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have been dealing with this same issue on my Dominator. With the cruise and idle happy, I had a lean spike just off idle. Tried quite a few things, but if I got the transition happy, something else was fat.
I went to my Holley book and noted that they make accel squirters to.050. So I broke out the drill bits. By .044, I couldn't feel a stumble any more, but could still see a spike on the LM log. At.050 there was very little spike left, but when easing around town, the graph will go to 10 or so A/F. Too fat, but the least of all the compromises I have found.
Also, if you do not have the 50cc cams, you are not getting the full shot from the 50cc pump.
Master, again and still
Re: Accelerator pump nozzle question [Re: Cab_Burge] #2405450
11/18/17 02:41 PM
11/18/17 02:41 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cab, i would believe as long as there is a vacuum signal at the t slot at wot, they will pull fuel accordingly. Also, just read that the t slot pulls in air at idle and does so until blade is cracked open. Then draws fuel.
Re: Accelerator pump nozzle question [Re: DaveRS23] #2405452
11/18/17 02:48 PM
11/18/17 02:48 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have 1 issue to clean up with my 1100 dom. When i stab the pri blades open and just on pri. When rpms get above 4000 the a/f wants to go lean and power falls off. I think it just needs more main jet as i have 80's in front. I have 2 more tunes i would like to try before i throw the cover on for winter.
Re: Accelerator pump nozzle question [Re: mopar dave] #2405522
11/18/17 05:16 PM
11/18/17 05:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
IMO .080's are too small and I run .084's on the primary w/a smaller carb at 3000+ altitude and it's a snappy angry fella........... beer
Re: Accelerator pump nozzle question [Re: Thumperdart] #2405550
11/18/17 06:08 PM
11/18/17 06:08 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I think yur right Dom. Being that it looks like im not on the boosters cruising i want to try square jetting again just for piece of mind . then i would like to add 2 or 4 sizes to pri and pull 2 from sec. Split jetting. Either way im real close now.
Re: Accelerator pump nozzle question [Re: Thumperdart] #2406887
11/21/17 04:02 PM
11/21/17 04:02 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
For me if the mixture screws have to be turned too far in say 1/2 turn from seated then I size down the ifr's and if they need to be like 2 turns out then bigger ifr's as a starting point. I size the idle bleeds according to the ifr's and go from there seeing/feeling the differences good and bad. I find the mixture screws play a HUGE role in how rich/lean the idle, transfer and cruise is on my Dart and there's a big difference between 1 3/4 turns out and 2 turns once it has heat in it. Same w/leaner mixtures, my car recovers faster when the happy peddle is mashed being in the 12-13 afr range while leaving a stop light and cruising instead of the 14-15's........... thumbs [/quote]
This is where I get confused. So; in my situation, I have a lean bog off idle but, my idle mixture screws are around a 1/2 to 3/4's of a turn from being seated. If you sized down the IFR's, then less fuel would be supplied to the transfer too and wouldn't that just make the condition worse?
Re: Accelerator pump nozzle question [Re: parksr5] #2406923
11/21/17 05:38 PM
11/21/17 05:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'd start by backin em out and see how it acts........... thumbs
Re: Accelerator pump nozzle question [Re: parksr5] #2406926
11/21/17 05:41 PM
11/21/17 05:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, since the build is slowly morphing into a FAST combo anyway, might as well get that AVS bolted on and start sorting it out now.
