Re: Pro Parts A Body 440 header install gone awry... [Re: 300by500] #240468
03/02/09 11:55 PM
03/02/09 11:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Leave the tabs on and use springs to hold the collectors on.That's what the Pro Stock cars do.
Nautilus Racing-
Re: Pro Parts A Body 440 header install gone awry... [Re: 300by500] #240469
03/02/09 11:57 PM
03/02/09 11:57 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the best is to support the moter up with a floorjack
mount the headers and if you cant use the mounts use a moter plate and take it from there
my 440 with 906 ,stage 3 max wegde heads and stage 6 heads where no problem
when I went to indy sr,s all I did was lowwer the moter down 3/8 and they fit great
1.39 9.85 - 137 mph
Re: Pro Parts A Body 440 header install gone awry... [Re: Ari440] #240470
03/03/09 01:04 AM
03/03/09 01:04 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Keep in mind that these headers were designed around the DC/MP BB Abody K member. As already said, a motor plate will help move the mill around to best fit the headers also.
By using either method, I have installed a few pair with minimal issues...
But sounds like you're on the right track to making them work...GOOD LUCK!
Re: Pro Parts A Body 440 header install gone awry... [Re: cgall] #240471
03/03/09 02:56 AM
03/03/09 02:56 AM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
Don, which side of the collector are the tabs on your passenger (Sharon's) side?
Tabs are toward the transmission on the passenger side.
Re: Pro Parts A Body 440 header install gone awry... [Re: RBDuster] #240472
03/03/09 04:43 PM
03/03/09 04:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I feel your pain. I bought a set of 2 1/8" Hookers for my 64 Belvedere. The motor is on a plate and still couldn't get the #1 & #5 tubes to clear the steering shaft & the left torsion bar. I had to cut and rotate the #1 tube. I flattened #5 and may cut it out and rotate it as well. I agree its all part of Hot Rodding. However I don't believe a new set of $700 (uncoated) headers should need 3-4 hours work to fit.
Good Luck Doug
Re: Pro Parts A Body 440 header install gone awry... [Re: dvw] #240473
03/03/09 07:29 PM
03/03/09 07:29 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Good Luck Doug
Are you talking about the Hookers? If not his are the old Pro parts headers not the new ones.
Re: Pro Parts A Body 440 header install [Re: moparmanjames] #2158065
09/20/16 12:50 PM
09/20/16 12:50 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Just put my old Pro Parts on 499 this summer other than tabs on Pass. side no problems after I cut header flanges put on turnouts,redid tabs on passenger side.(went to outside) have one problem #1 tube wont go straight in collector. Looks like it will have to be cut and fit right or I will just put collector on as far as it will go. What are some of your suggestions???????
Re: Pro Parts A Body 440 header install [Re: dare_dude] #2158090
09/20/16 01:46 PM
09/20/16 01:46 PM
fresno ca
mikeysmopars Offline
fresno ca
Just put on a set of the Mazzolini/ TTI Proparts 2 1/8 step headers, they are a pain and I don't have inner fenders.they touch the starter,oil pan,shock towers,transmission. They did however help my power. Mine is a low deck bb with Indy heads and Andy's plate. Only put them on to run last weekend, going to have some headers custom made, also gave me more tire clearance for 27" front.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Pro Parts A Body 440 header install [Re: 300by500] #2159205
09/22/16 01:28 AM
09/22/16 01:28 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Mikesmopar
How much hp did you gain
Also how much do they go for
1.39 9.85 - 137 mph
Re: Pro Parts A Body 440 header install [Re: Ari440] #2159213
09/22/16 01:51 AM
09/22/16 01:51 AM
fresno ca
fresno ca
Originally Posted By Ari440
Mikesmopar
I bought them direct from Bob Mazzolini cash no tax was $980, I had my hooker 1 7/8 and went a best of 9.89 1.38 60. 135 mph To these headers and the car went 9.64 @ 139 and a best of 1.35 60. I'm going to sell these and have some custom made.
Re: Pro Parts A Body 440 header install [Re: Ari440] #2159280
09/22/16 10:48 AM
09/22/16 10:48 AM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Just another thought! How did you go about painting yours?????
Re: Pro Parts A Body 440 header install [Re: mikeysmopars] #2159602
09/22/16 07:15 PM
09/22/16 07:15 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
They are tight using a low deck. Made for a RB engine. I used them on both 383 and 440.. had to massage them for the 383.
Nautilus Racing-
Re: Pro Parts A Body 440 header install [Re: 300by500] #2159654
09/22/16 08:48 PM
09/22/16 08:48 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Please Pm me if you sell them mike
Used header heat paint from a spray can
Touch them like six mouth time
1.39 9.85 - 137 mph
Re: Pro Parts A Body 440 header install [Re: Ari440] #2159677
09/22/16 09:19 PM
09/22/16 09:19 PM
JCFcuda Offline
JCFcuda  Offline
i've had my pro parts for a long time purchased them from Herb McCandless
68 barracuda elephant ears have them on stage six heads and Indy ezs. I thought they fit pretty well , Stage 6s hade 1/8 inch raised exhaust port .
Jim F
Re: Pro Parts A Body 440 header install [Re: 300by500] #2160604
09/24/16 01:16 AM
09/24/16 01:16 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I had the old pro-parts ones on my car for the original build and 1 season....
My engine is set back a little bit, and it is a low deck stroker with 441-1 heads and a 4 speed. Lots of thing working against me using a factory set of headers. We made them work for a while but they were hurting my power some, but still worked for what I needed.
They started to rust out just below the master cylinder so I pulled them and ended up building my own. Damon Kuhn basically designed, and tacked them together using a headman hustler weld up kit, with some extra U and J bends. Once they were tacked up I took them home and I spent about 15 hours tigging them up..... Best think I could have possibly done. I couldn't be happier with them. Just barely have to jack up the car and turn the wheels and I can pull them out in sections.. Easier plug access, but I have to use angled boots now.
My old ones pro-parts originals were a PIA. Had to cut one tube to get them out, then I piled the whole mess in a trash can in the back of the shop...Been meaning to throw them out! I suppose they would have worked well on a tall deck stock location engine, but they were ill fitting for my application...
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Pro Parts A Body 440 header install gone awry... [Re: 300by500] #2162338
09/26/16 09:16 PM
09/26/16 09:16 PM
New York
R/T1968R/T Online happy
R/T1968R/T  Online Happy
New York
Did you try to spin the mounts around? I had to spin mine from vertical to horizontal and the headers gained over 1/2" clearance. I have to ask, what is that bolt on the column, I dont have one...68 Valiant
