Transgo TF2
#2404062
11/15/17 05:46 PM
11/15/17 05:46 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
It seems there are 2 posible setups to install it... I can't recall the difference between both
Is it posible somebody enlight me about that ?
Re: Transgo TF2
[Re: NachoRT74]
#2404220
11/15/17 09:57 PM
11/15/17 09:57 PM
NachoRT74
Valencia, España
But what are the differences driving between 1 and 2
Re: Transgo TF2
[Re: NachoRT74]
#2404234
11/15/17 10:20 PM
11/15/17 10:20 PM
Posts: 12,215 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Upping the line pressure is probably the most important thing to longevity, assuming that is important to you. Some of the kits have the stiffer pressure spring and some do not.
The only possible down side to higher line pressure is the possibility of different shift points between 1st and 2nd and 2nd and 3rd commonly called split shifts.
Isn't the first set-up for trucks and towing? I think the second combo is the one you want, although I usually use the TF-3 kit. As long as the line pressure is enough to handle the load, the rest is not as big a deal.
What are your goals?
Master, again and still
Re: Transgo TF2
[Re: NachoRT74]
#2404419
11/16/17 10:50 AM
11/16/17 10:50 AM
NachoRT74
Valencia, España
my car is ( or will be again ) a driver though is a stroked 400 with 440 crank... 282HDP crower cam and MP 175K converter on 27" wheels with 3.55 SG... A/C. ( 74 Charger )
just want to get fun with it and still be the "perfect" driver... I guess this kit also reduce the crossover between shifts, so should get better "mileage" somehow (if can be that posible LOL ) ? I think I don't care to get a harder shift, but still decent for comfort on car. Trying to get the best of both worlds I guess
still not sure what differences could be felt if choosing stage 1 or stage 2
Re: Transgo TF2
[Re: lewtot184]
#2404583
11/16/17 07:23 PM
11/16/17 07:23 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The OP isn't asking the difference between the TF-1 and TF-2 but rather the different performance levels (race/street) within the TF-2. and that's a personal preference.
Re: Transgo TF2
[Re: NachoRT74]
#2404588
11/16/17 07:37 PM
11/16/17 07:37 PM
NachoRT74
Valencia, España
As John said, the difference between stage 1 and stage 2 BOTH from same TF-2 kit
Re: Transgo TF2
[Re: NachoRT74]
#2404619
11/16/17 09:10 PM
11/16/17 09:10 PM
John_Kunkel
Rio Linda, CA
Transgo keeps changing the kits and the instructions. The most recent TF-2 I have is several years old and the instructions differ from earlier versions.
The early versions had you enlarge (drill) some of the separator plate orifices depending on the firmness desired, now they have you remove a check ball to make the 1-2 shift as firm as it's gonna get...I totally disagree with this approach.
I'd recommend using older instructions with the current kit if it's the same as mine.
Re: Transgo TF2
[Re: NachoRT74]
#2404766
11/17/17 01:10 AM
11/17/17 01:10 AM
NachoRT74
Valencia, España
The kit is at this moment a thousand miles from home. Was bought maybe 5 years ago.
Still, with old or new instructions, what's the diff between st1 and st2
( i read what you said about the ball and drill size on an old thread created by CB at DC.com )
Re: Transgo TF2
[Re: NachoRT74]
#2404929
11/17/17 01:04 PM
11/17/17 01:04 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
still not sure what differences could be felt if choosing stage 1 or stage 2 Off topic but will you plz explain what all you had to do to get the 440 crank stuffed into the 400? Did you have to machine down the counterbalances? Which rods and pistons did you get? Did it need re-balancing? thx
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
Re: Transgo TF2
[Re: Prochargedmopar]
#2405028
11/17/17 03:57 PM
11/17/17 03:57 PM
NachoRT74
Valencia, España
there are many threads and info about the "451 stroker" becoming a 400 into a 440 ( dsplacement actually changes according the bore you choose, I went 0.020 making a 448... same as any 440 + 0.040" on a lighter assembly )... but I based on the simplier one: https://www.houstonmopars.org/stroker.htmlyou can use 440 rods, Chebby rods, etc... but I went for the cheaper and basic one using what I already had in hands with my 400 and just buying the pistons aftermarket to the job JUST IN CASE I HAVE FOR SALE NEW KB215 PISTONS SET STILL BOXED but in standard bore... if you are interested
Re: Transgo TF2
[Re: moparx]
#2405131
11/17/17 07:22 PM
11/17/17 07:22 PM
John_Kunkel
Rio Linda, CA
what check ball is this ? do you have a pic perhaps ? The check ball in the red circle blocks fluid on the 1-2 upshift and reroutes it through a control orifice....the size of the orifice then controls the firmness of the shift. When the ball is removed, uncontrolled full fluid flow makes the firmest shift. This is one of those no-buck mods to the TF (along with blocking the accumulator) that are often performed.
Re: Transgo TF2
[Re: NachoRT74]
#2405313
11/18/17 03:09 AM
11/18/17 03:09 AM
Prochargedmopar
Granbury TX
there are many threads and info about the "451 stroker" becoming a 400 into a 440 ( dsplacement actually changes according the bore you choose, I went 0.020 making a 448... same as any 440 + 0.040" on a lighter assembly )... but I based on the simplier one: https://www.houstonmopars.org/stroker.htmlyou can use 440 rods, Chebby rods, etc... but I went for the cheaper and basic one using what I already had in hands with my 400 and just buying the pistons aftermarket to the job JUST IN CASE I HAVE FOR SALE NEW KB215 PISTONS SET STILL BOXED but in standard bore... if you are interested Are these the ones? https://m.ebay.com/itm/Keith-Black-KB215-Pistons-Mopar-400-stroker-451/182421689243?epid=1874816046&hash=item2a792e139b:g:hCMAAOSw5cNYemGw
Re: Transgo TF2
[Re: NachoRT74]
#2405513
11/18/17 04:49 PM
11/18/17 04:49 PM
NachoRT74
Valencia, España
yeap! can let them go lower being out of ebay
